7298 Discussions
how to make a linear polynomial approximation by the least squares method
Serjio
Hello.
I have a function f = y (x).
 On the interval [a, b] I need to do a linear polynomial approximation of the data.
Linear means that the polynomial is of the first degree.
This means that it is described by two coefficients.
Those. I need to find two coefficients by which I can draw a red line like in the picture.
What MKL library functions can I do this?
mecej4
See page 221 of this. Change the names of the variables from t to x and b to y.
mecej4
You asked more or less the same question a month ago:
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/How-to-make-an-analogue-of-the-polyfit-function-from-Matlab/m-p/1286941
and the question was answered in that thread. In short, use the Lapack routine ?GELS.
Serjio
Yes you are right. The problem is I can't figure out how to use the Lapack routine ?GELS.
I have my x[200] and y[200] data.
How do I use my data in LAPACKE_dgels()?
info = LAPACKE_dgels(APACK_ROW_MAJOR,'N',m,n,nrhs,*a,lda,*b,ldb);
 And where will the result be? Where will the two coefficients be?
mecej4
ArpitaP_Intel
Glad to know that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thanks!
