7301 Discussions
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment.
sk7
[spriha@centosvm fftw2xc]$ make libintel64
make -f makefile lib _IA=intel64
make[1]: Entering directory '/opt/intel/oneapi/mkl/2021.3.0/interfaces/fftw2xc'
mkdir -p obj_double_intel
icc -Wall -Werror -c \
-DMKL_DOUBLE -I/opt/intel/oneapi/mkl/2021.3.0/include -I/opt/intel/oneapi/mkl/2021.3.0/include/fftw \
/opt/intel/oneapi/mkl/2021.3.0/interfaces/fftw2xc/wrappers/fftw.c -o obj_double_intel/fftw.o
icc: error #10417: Problem setting up the Intel(R) Compiler compilation environment. Requires 'install path' setting gathered from 'gcc'
make[1]: *** [makefile:129: obj_double_intel/fftw.o] Error 1
make[1]: Leaving directory '/opt/intel/oneapi/mkl/2021.3.0/interfaces/fftw2xc'
make: *** [makefile:109: libintel64] Error 2
VarshaS_Intel
Could you please check whether you have given the required permission and the correct installation paths?
Also, could you please provide us with the OS details and exact steps to reproduce the issue at our end also could you please elaborate on your issue?
We recommend you use the latest Intel MKL(2024.0) for more features and better performance.
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with an update on your issue?
Thanks & Regards,
Varsha
NoorjahanSk_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan
