incorrect dgemm results
ado
New User
I was using random matrix to test some code. I found dgemm gave wrong results sometimes. If I use truncated precision as copied from the console display, the results can be correct again. So I saved the generated matrix to a binary file and attached it (I changed the file extension to .cpp so I could upload it to this post). Could you take a look and let me know what went wrong?
output is incorrect:
 A=[
 7064610704830808.00000000 -2571117317297868.50000000 371407000938997.87500000
 6397257092471370.00000000 -2328238480630291.00000000 336322292936225.12500000
 -29483308061538568.00000000 10730250695401230.00000000 -1550022709306368.50000000
 -14929918819165514.00000000 5433643044981792.00000000 -784908978650044.00000000
 B=[
 -0.20072837 -0.01530215
 -0.57723645 -0.10924951
 -0.17790418 -0.46522968
 Out=[
 -2.00000000 -0.53125000
 0.27343750 1.50000000
 0.81250000 1.12500000
 -0.26562500 -2.68750000
#include <stdio.h>
#include <iostream>
#include <fstream>
#include <iomanip>
#include <mkl.h>
using namespace std;
void print_matrix( char* desc, MKL_INT m, MKL_INT n, double* a, MKL_INT lda );
int main()
		int m=4, n=3,k=2;
        double * A= new double [m*n];
        double * B= new double [n*k];
        double * out= new double [m*k];
		ifstream infile;
		infile.open("matrix3.cpp", ios::binary | ios::in);
        infile.read((char *)&A[0], m*n*sizeof(double));
        infile.read((char *)&B[0], n*k*sizeof(double));
        infile.close();
		cblas_dgemm(CblasRowMajor, CblasNoTrans, CblasNoTrans,
                m, k, n, 1.0, A, n, B, k, 0.0, out, k);
		print_matrix("A=[",m,n,A,n);
        print_matrix("B=[",n,k,B,k);
        print_matrix("Out=[",m,k,out,k);
		delete[] A;
		delete[] B;
		delete[] out;
		return 0;
void print_matrix( char* desc, MKL_INT m, MKL_INT n, double* a, MKL_INT lda ) {
        MKL_INT i, j;
        printf( "\n %s\n", desc );
        for( i = 0; i < m; i++ ) {
                for( j = 0; j < n; j++ ) printf( " %6.8f", a[i*lda+j] );
                printf( "\n" );
                printf( "]\n" );
ado
New User
please help, thanks!
Zhen_Z_Intel
Hi arth,
Please see our reply in https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/685034, I will close this post that is same question with above link. Thank you.
Fiona
