7287 Discussions
intel mkl pardiso to obtain determinant of matrix
chao_n_
I recently used the eigen with intel mkl pardiso to perform LDLT decomposition. It's much faster than other packages. I want to obtain the lower triangular matrix (matrixL) and diagonal matrix (vectorD) to calculate the determinant. Is it possible for intel mkl pardiso to obtain these two matrixes and how? Thanks.
Ruqiu_C_Intel
Thank you for reaching us. This issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
VidyalathaB_Intel
You can make use of the routine pardiso_getdiag which returns the diagonal elements of the matrix.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/sparse-solver-routines/onemkl-pardiso-parallel-direct-sparse-solver-iface/pardiso-getdiag.html
At present, there are no functions available for PARDISO API which can return LU factors.
Here are some of the forum threads where similar questions have been discussed.
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/MKL-PARDISO-get-L-U-factors/m-p/1265720#M31046
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Accessing-the-LU-factors-in-sparse-direct-solver/m-p/1279535#M31279
Since you want to compute the determinant maybe you can try DSS API (which is an alternative to PARDISO interface) dss_statistics https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/sparse-solver-routines/direct-sparse-solver-dss-interface-routines/dss-routines/dss-statistics.html#dss-statistics
Vidya.
chao_n_
Many thanks for your answers. I have some additional questions.
What's the difference between PARDISO API and DSS API?
 Does DSS API also use multi-thread?
Which is much faster?
Will PARDISO API add determinant function in the future?
VidyalathaB_Intel
>>....function in the future?
We are working on your issue. we will get back to you soon.
Vidya.
chao_n_
Thanks for your answer. You have missed some questions.
1) Does DSS API also use multi-thread?
2) What's the difference between PARDISO API and DSS API? Which is much faster?
Ruqiu_C_Intel
>>Yes, DSS API supports multi-thread.
>>DSS API is some kind of simplified API for beginners. Intel PARDISO API supports more options/features compare with DSS API.
Have a good day.
Ruqiu_C_Intel
