issue with LAPACKE_dormqr
Azua_Garcia__Giovann
I have a matrix A=QR and the QR decomposition is computed using LAPACKE_dgeqrf. To be more concrete A and the output QR are included below. At this point I append a new column to A and it becomes A1, A1 is included below as well. At this point, I try to apply an update which requires computing first Q'*A1 and therefore I use the function LAPACKE_dormqr. This below is the documentation and the way I am invoking it for my given matrices:
matrix A of dimensions 4 x 2:
7.500000e+01 4.000000e+00
4.000000e+01 2.800000e+01
6.600000e+01 5.000000e+00
1.800000e+01 1.000000e+01
matrix QR of dimensions 4 x 2:
-1.091100e+02 -1.768857e+01
2.172614e-01 -2.474095e+01
3.584813e-01 -5.777660e-02
9.776762e-02 1.640589e-01
matrix A1 of dimensions 4 x 3:
7.500000e+01 4.000000e+00 3.900000e+01
4.000000e+01 2.800000e+01 7.700000e+01
6.600000e+01 5.000000e+00 8.000000e+01
1.800000e+01 1.000000e+01 1.900000e+01
mklman.pdf MKL 10.3 Update 9:
C:
lapack_int LAPACKE_ormqr( int matrix_order, char side, char trans, lapack_int m,
lapack_int n, lapack_int k, const * a, lapack_int lda, const *
tau, * c, lapack_int ldc );
int l_order = LAPACK_COL_MAJOR;
lapack_int m = 4; // C->rows;
lapack_int n = 3; // C->cols;
lapack_int k = 3; // B->QR->rows;
lapack_int lda = m;
lapack_int ldc = m;
lapack_int info = 0;
lapack_int info = LAPACKE_dormqr(l_order, 'L', 'T', m, n, k, B->QR->data, lda, B->tau->data, C->data, ldc);
So far so good, but now the matrix coming out Q'*A1 is:
matrix Q'*A1 of dimensions 4 x 3
-1.091100e+02 -1.768857e+01 -1.065621e+02
0.000000e+00 -2.474095e+01 -4.110871e+01
0.000000e+00 0.000000e+00 3.281543e+01
0.000000e+00 8.881784e-16 -9.419678e+00
Cross checking with matlab turns out that the elements in column Q'*A1(:,3) are incorrect ... what am I doing wrong here?
This is the same but done using matlab:
>> A = [7.500000e+01 4.000000e+00;
4.000000e+01 2.800000e+01;
6.600000e+01 5.000000e+00;
1.800000e+01 1.000000e+01]
A =
75 4
40 28
66 5
18 10
>> A1 = [A [39 77 80 19]']
A1 =
75 4 39
40 28 77
66 5 80
18 10 19
>> [Q R] = qr(A)
Q =
0.6874 -0.3298 -0.5647 0.3161
0.3666 0.8696 -0.2063 -0.2585
0.6049 -0.2304 0.6340 -0.4232
0.1650 0.2862 0.4865 0.8088
R =
109.1100 17.6886
0 24.7410
0 0
0 0
>> Q'*A1
ans =
109.1100 17.6886 106.5621
0.0000 24.7410 41.1087
0.0000 0.0000 22.0579
-0.0000 -0.0000 -26.0582
The final matlab answer and the final MKL LAPACK answer are different in the last column:
>> Matlab=Q'*A1
Matlab =
>> MKL=[
-1.091100e+02 -1.768857e+01 -1.065621e+02;
0.000000e+00 -2.474095e+01 -4.110871e+01;
0.000000e+00 0.000000e+00 3.281543e+01;
0.000000e+00 8.881784e-16 -9.419678e+00]
MKL =
-109.1100 -17.6886 -106.5621
0 -24.7410 -41.1087
0 0 32.8154
0 0.0000 -9.4197
>> abs(Matlab) - abs(MKL)
ans =
0.0000 -0.0000 0.0000
0.0000 0.0000 -0.0000
0.0000 0.0000 -10.7575
0.0000 0.0000 16.6385
Why is it so different, what am I doing wrong when calling LAPACKE_dormqr?
Thanks in advance,
Giovanni
Ying_H_Intel
Hi Giovanni,
Your parameter setting should be correct. But the different result between MKL and Matlab should be the QR implementation itself.
for example, the below showA=QR. Theelements in Greenaresignificant. But
Red values could take any value with only one condition Q*Q^T=E.
As a result, MKL and Matlab have different last twocolumns, then different Q^T *A1 in last two row.
Ying
mecej4
A quick scan of your post showed me that you may be overlooking the fact that if A = Q R is the Q-R factorization, so also is (-Q) (-R), unless some additional restrictions are placed on R. Therefore, you should not compare only the Q-s or only the R-s given by Matlab and MKL. You should look at both.
Since Matlab itself uses MKL for internal operations, I would not expect to see any significant discrepancies.
Hello Mecej4,
I know what you mean but that's why I compare taking abs (see the end of my OP). It is also possible that the Q come different by permuting or changing signs for some row elements for a given column. But AFAIK Q'*C should give the same result specially like as you say matlab is just invoking MKL under the hood.
I guess this might have something to do with the way LAPACKE_dormqr works? Note that I am always using the compact QR representation upper trapezoidal R with lower min(M,N) householder reflectors and tau coeffients vector.
Giovanni
mecej4
> But AFAIK Q'*C should give the same result specially like as you say matlab > is just invoking MKL under the hood.
Two points:
1) The version of MKL used by Matlab need not be the same as the one used by your Fortran/C compiler.
2) If Matlab gives you Q1 and Fortran/C gives you Q2 = -Q1, Q1'C will be equal to -Q2'C, since you are supplying the C after the decomposition was performed.
Hi Mecej4,
Ok point taken :)
Could you confirm this is the right way to call the function?
QR is computed using DGEQRF over matrix B (m x (n - 1)).
C is a copy of matrix B with one extra column C (m x n).
C (m x n)
B->QR (m x (n - 1)) as returned by DGEQRF having MIN(m, n - 1) reflectors in the lower triangular.
lapack_int m = C->rows;
lapack_int n = C->cols;
lapack_int k = MIN(B->QR->rows, B->QR->cols);
lapack_int lda = m;
lapack_int ldc = m;
Many thanks in advance,
Giovanni
mecej4
Rather than my attempting to play "compiler", it will be more effective if you post your code. Assuming that it is not more than a couple of 100 lines, I'll be happy to take a look at it.
Ying_H_Intel
Hi Giovanni,
Ying
Hi Ying,
Thank you for following up on this :) I kinda of forgot this Thread already :) but is good to know. I got this bit working long ago.
Best!
Giovanni
