7303 Discussions
ldconfig: /opt/intel/oneapi/redist/lib/libmkl_sycl.so is not an ELF file
Orion_P_
Running AlmaLinux 8.9 with intel-oneapi-runtime-mkl-2024-2024.0.0-49656.x86_64
When running yum/dnf updates I get the following output:
Running transaction
ldconfig: /opt/intel/oneapi/redist/lib/libmkl_sycl.so is not an ELF file - it has the wrong magic bytes at the start.
VarshaS_Intel
From the information provided by you, we can see that you are using Alma Linux which is not a supported Operating System as per the  Intel MKL System Requirements. We recommend you use the supported Operating System.
Also, if your issue persists with the supported Operating Systems, could you please provide us with the details of the OS and the steps you have followed to reproduce the issue at our end?
Thanks & Regards,
Varsha
Orion_P_
AlmaLinux is a RedHat Enterprise Linux clone like CentOS and Rocky Linux, so it should be equivalent.
Hower I can reproduce it on RHEL8.9 with:
[email protected] [~]# yum install intel-oneapi-runtime-mkl-2024-2024.0.0-49656.x86_64 -y
Updating Subscription Management repositories.
Last metadata expiration check: 18:34:17 ago on Tue 05 Dec 2023 02:08:55 PM MST.
Dependencies resolved.
Package                                            Arch      Version             Repo       Size
Installing:
intel-oneapi-runtime-mkl-2024                      x86_64    2024.0.0-49656      oneAPI    149 M
Installing dependencies:
intel-oneapi-runtime-compilers-2024                x86_64    2024.0.0-49819      oneAPI     34 M
intel-oneapi-runtime-compilers-common-2024         noarch    2024.0.0-49819      oneAPI     16 k
intel-oneapi-runtime-dpcpp-cpp-2024                x86_64    2024.0.0-49819      oneAPI     12 k
intel-oneapi-runtime-dpcpp-cpp-common-2024         noarch    2024.0.0-49819      oneAPI     26 k
intel-oneapi-runtime-dpcpp-sycl-core-2024          x86_64    2024.0.0-49819      oneAPI    2.8 M
intel-oneapi-runtime-dpcpp-sycl-cpu-rt-2024        x86_64    2024.0.0-49819      oneAPI    6.6 k
intel-oneapi-runtime-dpcpp-sycl-fpga-emul-2024     x86_64    2024.0.0-49819      oneAPI     11 k
intel-oneapi-runtime-dpcpp-sycl-opencl-cpu-2024    x86_64    2024.0.0-49819      oneAPI     93 M
intel-oneapi-runtime-dpcpp-sycl-rt-2024            x86_64    2024.0.0-49819      oneAPI    6.6 k
intel-oneapi-runtime-mkl-common-2024               noarch    2024.0.0-49656      oneAPI     23 k
intel-oneapi-runtime-opencl-2024                   x86_64    2024.0.0-49819      oneAPI     64 k
intel-oneapi-runtime-openmp-2024                   x86_64    2024.0.0-49819      oneAPI     19 M
intel-oneapi-runtime-openmp-opencl-shared-2024     x86_64    2024.0.0-49819      oneAPI    3.8 M
intel-oneapi-runtime-tbb-2021                      x86_64    2021.11.0-49513     oneAPI    954 k
intel-oneapi-runtime-tbb-common-2021               noarch    2021.11.0-49513     oneAPI     24 k
intel-oneapi-runtime-tcm-1                         x86_64    1.0.0-435           oneAPI    1.2 M
Transaction Summary
Install  17 Packages
[email protected] [~]# ldconfig
bytes at th
e start
VarshaS_Intel
Thanks for the details.
We are able to reproduce your issue at our end. We are working on your issue internally, we will get back to you soon.
Thanks & Regards,
Varsha
MarthaSlaughter
I am having the same problem, installing on SLES12 SP5.  Would you please provide a working libmkl_sycl.so[.3] file?
ls -al /<somedir>/intel/oneapi/mkl/2024.0/lib | grep libmkl_sycl
-rw-r--r-- 1 mslaught tmgtools 960730860 Oct 26 14:59 libmkl_sycl.a
-rwxr-xr-x 1 mslaught tmgtools 144 Oct 26 14:59 libmkl_sycl.so
lrwxrwxrwx 1 mslaught tmgtools 21 Nov 15 19:32 libmkl_sycl_blas.so -> libmkl_sycl_blas.so.4
-rwxr-xr-x 1 mslaught tmgtools 101199688 Oct 26 14:59 libmkl_sycl_blas.so.4
lrwxrwxrwx 1 mslaught tmgtools 29 Nov 15 19:32 libmkl_sycl_data_fitting.so -> libmkl_sycl_data_fitting.so.4
-rwxr-xr-x 1 mslaught tmgtools 10966304 Oct 26 14:59 libmkl_sycl_data_fitting.so.4
lrwxrwxrwx 1 mslaught tmgtools 20 Nov 15 19:32 libmkl_sycl_dft.so -> libmkl_sycl_dft.so.4
-rwxr-xr-x 1 mslaught tmgtools 52730120 Oct 26 14:59 libmkl_sycl_dft.so.4
lrwxrwxrwx 1 mslaught tmgtools 23 Nov 15 19:32 libmkl_sycl_lapack.so -> libmkl_sycl_lapack.so.4
-rwxr-xr-x 1 mslaught tmgtools 46722400 Oct 26 14:59 libmkl_sycl_lapack.so.4
lrwxrwxrwx 1 mslaught tmgtools 20 Nov 15 19:32 libmkl_sycl_rng.so -> libmkl_sycl_rng.so.4
-rwxr-xr-x 1 mslaught tmgtools 139976664 Oct 26 14:59 libmkl_sycl_rng.so.4
lrwxrwxrwx 1 mslaught tmgtools 23 Nov 15 19:32 libmkl_sycl_sparse.so -> libmkl_sycl_sparse.so.4
-rwxr-xr-x 1 mslaught tmgtools 126036688 Oct 26 14:59 libmkl_sycl_sparse.so.4
lrwxrwxrwx 1 mslaught tmgtools 22 Nov 15 19:32 libmkl_sycl_stats.so -> libmkl_sycl_stats.so.4
-rwxr-xr-x 1 mslaught tmgtools 36150344 Oct 26 14:59 libmkl_sycl_stats.so.4
lrwxrwxrwx 1 mslaught tmgtools 19 Nov 15 19:32 libmkl_sycl_vm.so -> libmkl_sycl_vm.so.4
-rwxr-xr-x 1 mslaught tmgtools 182190512 Oct 26 14:59 libmkl_sycl_vm.so.4
Note that libmkl_sycl.so is 144 characters.  Its file type:
file libmkl_sycl.so
libmkl_sycl.so: ASCII text
Martha
Gennady_F_Intel
the problem would be fixed the next update of oneMKL. We will keep this thread updated.
as a temporarily workaround you could just remove libmkl_sycl.so
lzyla
same issue here on ubuntu 23.10
jdal
This is also happening with ubuntu 22.04.3. The file has a length of 144 and doesn't appear to have been properly compiled.
-rwxr-xr-x 1 root root 144 Oct 26 15:59 /opt/intel/oneapi/mkl/latest/lib/libmkl_sycl.so
(base) jd@muir:~$ ls -lrth /opt/intel/oneapi/mkl/2024.0/lib/*sy*
-rwxr-xr-x 1 root root 144 Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl.so
-rwxr-xr-x 1 root root 45M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_lapack.so.4
-rwxr-xr-x 1 root root 51M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_dft.so.4
-rwxr-xr-x 1 root root 11M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_data_fitting.so.4
-rwxr-xr-x 1 root root 97M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_blas.so.4
-rw-r--r-- 1 root root 917M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl.a
-rwxr-xr-x 1 root root 174M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_vm.so.4
-rwxr-xr-x 1 root root 35M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_stats.so.4
-rwxr-xr-x 1 root root 121M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_sparse.so.4
-rwxr-xr-x 1 root root 134M Oct 26 15:59 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_rng.so.4
lrwxrwxrwx 1 root root 21 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_blas.so -> libmkl_sycl_blas.so.4
lrwxrwxrwx 1 root root 19 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_vm.so -> libmkl_sycl_vm.so.4
lrwxrwxrwx 1 root root 22 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_stats.so -> libmkl_sycl_stats.so.4
lrwxrwxrwx 1 root root 23 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_sparse.so -> libmkl_sycl_sparse.so.4
lrwxrwxrwx 1 root root 20 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_rng.so -> libmkl_sycl_rng.so.4
lrwxrwxrwx 1 root root 23 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_lapack.so -> libmkl_sycl_lapack.so.4
lrwxrwxrwx 1 root root 20 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_dft.so -> libmkl_sycl_dft.so.4
lrwxrwxrwx 1 root root 29 Oct 26 19:13 /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl_data_fitting.so -> libmkl_sycl_data_fitting.so.4
The contents are the following:
cat /opt/intel/oneapi/mkl/2024.0/lib/libmkl_sycl.so
INPUT(-lmkl_sycl_blas -lmkl_sycl_lapack -lmkl_sycl_sparse -lmkl_sycl_dft -lmkl_sycl_vm -lmkl_sycl_rng -lmkl_sycl_stats -lmkl_sycl_data_fitting)
Gennady_F_Intel
as we noticed above, the problem will be fixed in the next update ( 2024.1) of oneMKL.
check the MKL Linker Adviser to see how properly links against oneMKL.
cpmech
The issue persists in 2024.2
crobar
Issue persists in 2025.0
at least when installing from apt on Ubuntu
JW___mkl
Same issue on 2025.0 on RHEL/Fedora
See the `xxd` dump below:
xxd /opt/intel/oneapi/mkl/latest/lib/libmkl_sycl.so
00000000: 494e 5055 5428 2d6c 6d6b 6c5f 7379 636c  INPUT(-lmkl_sycl
00000010: 5f62 6c61 7320 2d6c 6d6b 6c5f 7379 636c  _blas -lmkl_sycl
00000020: 5f6c 6170 6163 6b20 2d6c 6d6b 6c5f 7379  _lapack -lmkl_sy
00000030: 636c 5f73 7061 7273 6520 2d6c 6d6b 6c5f  cl_sparse -lmkl_
00000040: 7379 636c 5f64 6674 202d 6c6d 6b6c 5f73  sycl_dft -lmkl_s
00000050: 7963 6c5f 766d 202d 6c6d 6b6c 5f73 7963  ycl_vm -lmkl_syc
00000060: 6c5f 726e 6720 2d6c 6d6b 6c5f 7379 636c  l_rng -lmkl_sycl
00000070: 5f73 7461 7473 202d 6c6d 6b6c 5f73 7963  _stats -lmkl_syc
00000080: 6c5f 6461 7461 5f66 6974 7469 6e67 290a  l_data_fitting).
Looks like an issue with your build scripts.
Viraj_M_Intel
Starting 2024.0, mkl_sycl library is split into domain-specific libraries. This is particularly helpful when redistributing oneMKL with only specific domain functionality.
libmkl_sycl.so is not an ELF file but it is a linker script which links the application with all oneMKL supported domains using the INPUT command:
Hence, the ASCII file type is expected.
Your installation will contain the files listed above within the INPUT command.
More on linker scripts and commands: Using LD, the GNU linker - Command Language
Is there a problem other than the file type that affects linking with oneMKL or with ldconfig usage after 2024.1 release?
JW___mkl
Thanks @Viraj_M_Intel this makes sense
Orion_P_
I'll just note that with intel-oneapi-runtime-mkl-2025.1.0-801.x86_64 this file is no longer present.
Shiquan_Su
In my oneapi 2025.1 installation, I can find libmkl_sycl.so here:
$ ls /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl*
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl.a /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_rng.so
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_blas.so /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_rng.so.5
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_blas.so.5 /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl.so
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_data_fitting.so /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_sparse.so
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_data_fitting.so.5 /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_sparse.so.5
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_dft.so /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_stats.so
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_dft.so.5 /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_stats.so.5
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_lapack.so /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_vm.so
/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_lapack.so.5 /opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_sycl_vm.so.5
Orion_P_
Sure, but that's not a path in /etc/ld.so.conf.d/intel-oneapi-runtime.conf and so ldconfig no longer complains about it.
