libmkl_lapack.so undefined symbol dlasr_lvb
John_L_4
I'm trying to compile a Fortran mex-file in Matlab that uses MKL with the Fortran 95 interfaces. I'm running on a Linux machine and I'm using the em64t versions of the dynamic MKL libraries.
I can get the mex-file to compile and link without any errors. The problem is at run time.
TheLAPACK routine that the mex-file calls isMGESV. At run time I get the error:
/opt/intel/mkl/9.1/lib/em64t/libmkl_lapack.so: undefined symbol dlasr_lvb
My link line(using g++) has the libraries in the following order:
-lmkl_lapack95 -lmkl_blas95 -lmkl_lapack -lmkl -lvml -lguide -lpthread -lm
If I try linking against the static libraries I get a seg fault at run time.
I'm not sure if the above is enough information for anybody to help.
John
