link R with MKL
Qiuping_X_Intel
I am linking MKL with R in Mac. After set the link as
ln -s /opt/intel/compilers_and_libraries_2016.2.146/mac/mkl/lib/libmkl_rt.dylib /Library/Frameworks/R.framework/Versions/3.2/Resources/lib/libRblas.dylib
The link file looks file, but when I start the R program, it always complains
Error in dyn.load(file, DLLpath = DLLpath, ...) :
  unable to load shared object '/Library/Frameworks/R.framework/Versions/3.2/Resources/library/stats/libs/stats.so':
  dlopen(/Library/Frameworks/R.framework/Versions/3.2/Resources/library/stats/libs/stats.so, 6): Library not loaded: /Library/Frameworks/R.framework/Versions/3.2/Resources/lib/libRlapack.dylib
  Referenced from: /Library/Frameworks/R.framework/Versions/3.2/Resources/library/stats/libs/stats.so
  Reason: Incompatible library version: stats.so requires version 3.2.0 or later, but libRblas.dylib provides version 0.0.0
During startup - Warning message:
package ‘stats’ in options("defaultPackages") was not found
Please Help, thanks .
