link line advisor for pardiso solver
eddywu
I'm trying to compile code that uses the pardiso solver.  The machine I'm using is a linux machine. I'm using an autoconfig file to compile the code. I used the link line advisor to specify flags needed for my autoconfig and set the environment variables needed.
The autoconfig file is below:
#!/bin/sh
../configure \
CXXFLAGS="-O3 -fopenmp -std=c++11" \
ARCHDIR="$HOME/XyceLibs/Parallel" \
CPPFLAGS="-DMKL_ILP64 -m64 -fPIC -I$MKLROOT/include" \
LDFLAGS="-m64 ${MKLROOT}/lib/libmkl_scalapack_ilp64.a -Wl,--start-group ${MKLROOT}/lib/libmkl_intel_ilp64.a ${MKLROOT}/lib/libmkl_intel_thread.a ${MKLROOT}/lib/libmkl_core.a ${MKLROOT}/lib/libmkl_blacs_openmpi_ilp64.a -Wl,--end-group -liomp5 -lpthread -lm -ldl" \
--enable-mpi \
CXX=mpicxx \
CC=mpicc \
F77=mpif77 \
--enable-stokhos \
--enable-amesos2 \
--prefix=$HOME/XyceInstall/Parallel \
when I try to compile this code, I get the error attached.  I believe I don't have the correct flags set for my autoconfig file. The config log is also attached. I'm wondering if I could get some advice on how to resolve my issue.
The code I'm trying to compile is Xyce using trilinos with third party math functions.
Fengrui
Could you try linking to oneMKL dynamically?
eddywu
Hi @Fengrui ,
Thanks for the reply. Yes that helped it build. I now have the code built, but now I'm experiencing an issue with segmentation faults when trying to run my application.
These are the error messages I get.
[imagica-thinkstation:500114] *** Process received signal ***
[imagica-thinkstation:500114] Signal: Segmentation fault (11)
[imagica-thinkstation:500114] Signal code: Address not mapped (1)
[imagica-thinkstation:500114] Failing at address: 0x55d84b4439a8
[imagica-thinkstation:500114] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f2d54842520]
[imagica-thinkstation:500114] [ 1] /opt/intel/oneapi/mkl/2024.0/lib/libmkl_avx2.so.2(mkl_blas_avx2_xidamax_nonan+0xa9)[0x7f2d494503c9]
[imagica-thinkstation:500114] [ 2] /opt/intel/oneapi/mkl/2024.0/lib/libmkl_avx2.so.2(mkl_blas_avx2_xidamax+0x40)[0x7f2d497122d0]
[imagica-thinkstation:500114] [ 3] /opt/intel/oneapi/mkl/2024.0/lib/libmkl_intel_thread.so.2(mkl_blas_idamax+0x3ee)[0x7f2d5a0552ee]
[imagica-thinkstation:500114] [ 4] /opt/intel/oneapi/mkl/2024.0/lib/libmkl_intel_ilp64.so.2(idamax+0xa6)[0x7f2d5c6bf8f6]
[imagica-thinkstation:500114] [ 5] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x2635fb2)[0x55a84a0d9fb2]
[imagica-thinkstation:500114] [ 6] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x26a8dcb)[0x55a84a14cdcb]
[imagica-thinkstation:500114] [ 7] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x9faa27)[0x55a84849ea27]
[imagica-thinkstation:500114] [ 8] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x9e045b)[0x55a84848445b]
[imagica-thinkstation:500114] [ 9] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x9e54e8)[0x55a8484894e8]
[imagica-thinkstation:500114] [10] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x9eefb2)[0x55a848492fb2]
[imagica-thinkstation:500114] [11] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x9ef3a8)[0x55a8484933a8]
[imagica-thinkstation:500114] [12] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x8e36bf)[0x55a8483876bf]
[imagica-thinkstation:500114] [13] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x8e6304)[0x55a84838a304]
[imagica-thinkstation:500114] [14] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x3b627d)[0x55a847e5a27d]
[imagica-thinkstation:500114] [15] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x3c1098)[0x55a847e65098]
[imagica-thinkstation:500114] [16] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x39b054)[0x55a847e3f054]
[imagica-thinkstation:500114] [17] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f2d54829d90]
[imagica-thinkstation:500114] [18] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f2d54829e40]
[imagica-thinkstation:500114] [19] /home/imagica/XyceInstall/Parallel/bin/Xyce(+0x3af465)[0x55a847e53465]
[imagica-thinkstation:500114] *** End of error message ***
The autoconfig file I use to compile without error is below:
#!/bin/sh
../configure \
LDFLAGS=" -m64 -L${MKLROOT}/lib -lmkl_scalapack_ilp64 -Wl,--no-as-needed -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_ilp64 -liomp5 -lpthread -lm -ldl" \
--enable-mpi \
CXX=mpicxx \
CC=mpicc \
F77=mpif77 \
--enable-stokhos \
--enable-amesos2 \
