linking problem with mkl on Snow Leopard
irhooper2
I am trying to link a program using mkl with ifort on snow leopard to enable use of LAPACK routines in my code. I am using the following link flags:
-L$(MKLPATH) -I$(MKLINCLUDE) -I$(MKLINCLUDE)/em64t/lp64 -lmkl_lapack95_lp64 $(MKLPATH)/libmkl_intel_lp64.a $(MKLPATH)/libmkl_intel_thread.a $(MKLPATH)/libmkl_core.a $(MKLPATH)/libmkl_intel_thread.a $(MKLPATH)/libmkl_core.a $(MKLPATH)/libmkl_intel_thread.a $(MKLPATH)/libmkl_core.a -liomp5 -lpthread
with the following:
MKLPATH = /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/em64t
MKLINCLUDE = /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/include/em64t/ilp64
a suggested from the MKL user manual (but removing the - wl,--start-group and -wl,--end group commands as they don't seem to work).
When compiling I get the following error:
ld: in /Developer/opt/intel/Compiler/11.1/067/Frameworks/mkl/lib/em64t/libmkl_core.a(dlamch.o), ObjectFileAddressSpace::mappedAddress(0xFFFFFFFFFFFFFFFC) not in any section
Can anybody help? I have seen on the sticky at the top of the forum page that there is an update of mkl for snow leopard but when I try to obtain this by clicking on my mkl license in registration centre I get the following message:
he product updates/upgrades below are available based on your support subscription status.
We are unable to find registrations/downloads matching this request
Thanks in advance,
Ian
Ron_Green
Quoting - irhooper2
with the following:
Thanks in advance,
Ian
Ian,
I am transferring your issue over to the MKL User Forum.
ron
Gennady_F_Intel
Quoting - irhooper2
with the following:
Thanks in advance,
Ian
Ian, this is well-known problem with static linking on SnowLeo.
Please refer to the link : http://software.intel.com/en-us/articles/linking-error-on-macosx-106-with-xcode-32/
--Gennady
irhooper2
Ian, this is well-known problem with static linking on SnoLeo.
--Gennady
Gennady, thanks for your quick reply. I have a couple of problems with the information on the suggested page:
1) I'm not using xcode at all, I'm compiling from command line with my own Makefile so should I still be experiencing this problem?
2) Using 10.5 isn't an option
3) Using dynamic linking causes all sorts of other problems. After setting the DYLD_LIBRARY_PATH environment variables and writing my Makefile to use the dynamic libraries I get a dyld library not loaded error. Clearly I'm doing something wrong but I'll be damned if I can figure it out.
I guess my only other option at the moment is to learn how to use xcode and use dynamic libraries unless you have any other suggestions?
Ian
Artem_V_Intel
Quoting - irhooper2
--Gennady
Ian
Hello Ian,
Please take a look at the attached simple example of dynamic linking against MKL.
This is an example of using LAPACK dgetrf function from the MKL examples. To unpack this archive please invoke the next command
tar xjvf dynamic-linkage.tar.bz2
After that do the following:
cd ./dynamic-linkage
make
cat dgetrfx.d | ./test
The output should be like this:
DGETRF Example Program Results
Details of factorization
1 2 3 4
1 5.2500 -2.9500 -0.9500 -3.8000
2 0.3429 3.8914 2.3757 0.4129
3 0.3010 -0.4631 -1.5139 0.2948
4 -0.2114 -0.3299 0.0047 0.1314
IPIV
2 2 3 4
Also Link Line Advisor tool may be very hepful for you.
Art
