lmkl
moukouri
I recently moved to the new compiler version 11.1 from 11.0. My program
compiles fine. However, I am unable to link. One of my old flags was -lmkl.
I notice that the library libmkl.so is missing in the new version. What is the
equivalent one?
TimP
There's no change here since 11.0 compilers. As compared with MKL before 10.0, it's complicated enough that you should read the notes in the docs/mkl/ directory, or look for posts on this forum which might help you decide.
Gennady_F_Intel
moukori,
yes, tim18 is right, there's no change since 11.0 compiler.
Regarding MKL 10.2 (incorporated in compiler 11.1 ): versions10.x of Intel MKL were re-architected completely by separating the interface, threading and computational components of the product.
Please see the KB article "Intel Math Kernel Library Link Line Advisor".
I hope it helps you to select needed libraries for linking your application.
--Gennady
moukouri
moukori,
--Gennady
Hi Tim and Gennady,
Thanks for your replies. I saw that the numbers of files are different between the current version
and the old one. Most importantly the library limkl.so is missing. I will check with our administrator.
Moukouri
