make problem for mkl
MXY6
Hi, recently I build a project using mkl through make, my simple CMakeLists is like this,
cmake_minimum_required(VERSION 3.14)
project(ex5 Fortran)
enable_language(Fortran)
find_package(MKL REQUIRED)
include_directories(${MKL_INCLUDE})
add_executable(ex5 main.f90)
target_link_libraries(ex5 ${MKL_LIBRARIES})
#target_link_options(ex5 PUBLIC $<LINK_ONLY:MKL::MKL>)
If I use target_link_libraries(ex5 ${MKL_LIBRARIES}), I can successfully build the project, but not for
#target_link_options(ex5 PUBLIC $<LINK_ONLY:MKL::MKL>), which shows this error,
ifort: error #10236: File not found: 'MKL::MKL'
could you help solve this?
JaideepK_Intel
We are investigating your issue at our end, Could you please share the mkl version for better understanding.
Jaideep
MXY6
Thanks for your response. My mkl version is 2021.4 for Mac os
VidyalathaB_Intel
Thanks for providing the details.
The issue raised by you is reproducible from our end as well.
We are looking into this issue. We will get back to you soon.
Vidya.
Khang_N_Intel
Hi Meng,
We have tested with oneMKL 2021.4 and confirmed the issue. We have escalated this issue to the MKL team.
We will let you know when we have the solution for this problem.
Best regards
Khang
Khang_N_Intel
Hi Meng,
cmake function target_link_options inserts the target as is, target_link_libraries should be used in order to resolve MKL target correctly.
Please refer to CMakeLists.txt from oneMKL Fortran examples for the correct way how to include oneMKL to CMake project for classic Fortran API:
<install_path>/oneapi/mkl/2021.4.0/examples/examples_core_f.tgz/f/CMakeLists.txt:
target_compile_options(${func} PUBLIC ${TEST_COPT} $<TARGET_PROPERTY:MKL::MKL,INTERFACE_COMPILE_OPTIONS>)
target_link_libraries(${func} PUBLIC ${TEST_LOPT} $<LINK_ONLY:MKL::MKL>)
This should fix it.
Khang
