matmul_mkl
Deleted_U_Intel
Hi all,
after our admins recently upgraded the Intel Compiler/MKL, I started getting errors during linking:
isoepsilon_matrix_RPA.f90:(.text+0x29d1): undefined reference to `matmul_mkl_'
I compile the source files with
ifort -openmp -parallel -heap-arrays -O3 -lmkl -c
and link using
ifort -openmp -parallel -heap-arrays *.o
-Wl,--start-group /sw/linux/intel/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libmkl_intel_lp64.a /sw/linux/intel/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libmkl_intel_thread.a /sw/linux/intel/composer_xe_2011_sp1.6.233/mkl/lib/intel64/libmkl_core.a -Wl,--end-group -openmp -lpthread
Linking is only successful, if I use -no-opt-matmul during the source file compilation.
Any ideas what is causing this?
Bjoern
Vladimir_Petrov__Int
New Contributor III
Hi Bjoern,
Please add libmatmul.a from the compiler distribution to your link line.
Vladimir
bacchiocchi__corrado
Hi everybody,
I have a similar problem when trying to compile using the Fortran Compiler of Intel® Parallel Studio XE 2018.
I use the following flags for compilation: -fast -parallel -qopenmp -qopt-matmul -axCOMMON-AVX512 -ftz -ip -pad -unroll-aggressive
and these for linking: -parallel -qopenmp -lmatmul -qopt-report=5
At the linking stage I keep getting this kind of message:
ipo_out.f:(.text+0x255af): undefined reference to `matmul_mkl_f64_'
Any suggestion?
Thanks a lot in advance
Corrado
