matrix distribution in pdgemm and pdgesvx
oguren
I want to solve linear equation system like
A*X=B*C;
sizeof A=(MxM) sizeof X=(MxN)
sizeof B=(MxM) sizeof C=(MxN)
I set grid as (pxq) and block size is same in both direction as nb.
I can calculate B*C from pdgemm_ routine.It uses block cyclic distribution.I can distribute the matrices as I want.
A*X=D=B*C can be solved from pdgesv_ routine. but this routine use block distribution.
for example when M=3, N=3, p=3,q=3,nb=3 it work correctly
on the ohter and,
when M=18,N=18,p=3,q=3,nb=3 it fails, you have to give nb=18/3=9
So you can't distribute the matrices as you want. you always have to arrange block size or matrix size to provide M%p=0 && N%q=0. if your matrix is to be prime number or etc. it is unsolvable with scalapack routines. is there any way to solve system, according to pdgemm distribution.
Thank,
Alex_Kosenkov
Hello, oguren,
Could you please narrow down how exactly do you do 2D-block cyclic distribution?
Thank you,
Alexander
