7298 Discussions
mkl 10 error: not convinient for this processor
Ying_D_Intel
I am trying mkl10 on em64t machines and goterror at run time:
MKL FATAL ERROR: SO k/kernel/source/xormrq_omp.fxx;mkl_lapack_zunmrq;323;333;; not convinient for this processor.
We linked libs from $MKLDIR/lib/em64t. (*_lp64.*)
Any idea what could cause the problem?
Ying
TimP
The problem seems more likely to happen if you attempt to use the IA-64 libraries from /lib/64/. All /em64t/ and /32/ libraries should be compatible with em64t
Ying_D_Intel
I use lib/em64t on Intel Xeon machine.
libmkl_intel_thread.so and libpthread.so were also linked in. Not sure if that could be a problem?
Islibmkl_em64t.a required for em64t?
Ying
TimP
Those libraries are normal. libmkl_thread requires also libguide or libiomp5.
libmkl_em64t.a in MKL 10 is a shortcut for libmkl_intel_lp64.a libmkl_thread.a libmkl_core.a. You should not try to link both .a and .so versions of any one library.
Ying_D_Intel
Thanks for your reply. Appreciate it.
I have mkl_lapack .a and .so linked in my program. Would this possibly be the reason of the error "not convenient for the processor"? but I have the same link line when I used mkl 9, which worked fine.
Or any other idea?
TimP
Generally, it's risky to have more than one copy of the same library linked in. The MKL 10 documents specifically warn about the danger of that when using static libraries.
9.1 and 10 are significantly different in their library organization. Since mkl_lapack.a and .so in MKL 10 are not actually libraries, but are lists of 3 libraries, there is more opportunity to go wrong if you use those lists (scripts) and also link against a possibly conflicting library.
Ying_D_Intel
I am now using only libmkl_lapack.a in my program. But still have the same problem. What can I do to helpfurther investigate/debug the issue?
Ying
Gennady_F_Intel
Could you show the linking line of  this example? Please check how do link this version properly vie MKL Linker Adviser: http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor
a couples of  comments - version 10.0 is no longer supported. In the case if you will use 10.0 on the latest microarchitectures, then you will not get the all performance benefits from MKL's optimizations.
--Gennady
mecej4
Gennady,
You probably did not notice that the post that you responded to was from 2008! There seems to be a new problem with the forum software that is bringing old and stale posts, often from many years ago, to the top of the list. If anyone responds to the post without noticing the date, the thread becomes "active" and adds to the confusion.
Gennady_F_Intel
You are right  - i didn't noticed that. Thanks a lot, mecej.  the thread is not active and the topic is not actual now.
SergeyKostrov
Valued Contributor II
>>...You probably did not notice that the post that you responded to was from 2008! There seems to be a new problem >>with the forum software that is bringing old and stale posts, often from many years ago, to the top of the list. If anyone >>responds to the post without noticing the date, the thread becomes "active" and adds to the confusion... The same problem happened with Intel C++ compiler and IPP forums. By some unknown reason lots of very old threads were marked as threads with New Posts. Did it happend because of some IDZ website maintenance activities?
SergeyKostrov
Update and a note to a Moderator: >>>>...You probably did not notice that the post that you responded to was from 2008!.. >>... >>The same problem happened with Intel C++ compiler and IPP forums... I just verified and almost every IDZ forum is affected by that problem!
