mkl_c.lib - 64bit equivalent
davidspurr
(w_cprof_p_11.0.061, MKL 10.1.0.018)
I have a program with one subroutine that uses a couple of RNG functions from MKL. The program compiles 'OK' as a 32bit application (only 'OK' because I do get a warning message about mkl_c.lib, but the RNG's were working when I last used that part of the program about 20 months ago.)
However, when I now attempt to compile it as a 64bit app, I get a fatal link error.
error LNK2019: unresolved external symbol VSLNEWSTREAM referenced in function PARAMETRIC
error LNK2019: unresolved external symbol VSRNGGAUSSIAN referenced in function PARAMETRIC
For the 32bit app I have mkl_c.lib & libguide.lib as additional dependencies (Configuration Properties / Linker / Input).
When I encountered problems compiling as a 64bit app, I found I had no additional dependencies for 64bit compiler, so I copied in mkl_c.lib & libguide.lib, but then I get the following error:
fatal error LNK1181: cannot open input file 'mkl_c.lib' LINK
I then discovered that there is no mkl_c.lib for 64bit; ie no such file in
C:\\Program Files\\Intel\\MKL\\10.1.0.018\\ia64\\lib
or anywhere else I looked in the 64bit folders.
Can anyone please advise what lib's I need to specify to get the RNG functions from MKL to work in a 64bit app?
I tried mkl_intel_c.lib and mkl_core.lib but still get fatal error LNK1181.
ArturGuzik
Valued Contributor I
David,
as in my reply to your previous post, and according to the release notes and KB, the replacement for the stub mkl_c.lib are (for x64): mkl_intel_thread.lib mkl_core.lib. So you need both of them and your integers model (lp or ilp). Also using libiomp5md.lib instead of old libguide is usually recommended.
you can take a look at this KB article.
But you error message suggests your linker still wants mkl_c.lib, so maybe you refer to it somewhere.
A.
davidspurr
After more experimenting & now using mkl_intel_thread.lib mkl_core.lib & libiomp5md.li, I no longer get the "fatal error LNK1181" message, which I guess means it is finding those lib files OK.
However, I am now back to my original messages:
I have done something a little 'non-standard' in that I have the contents of modules "MKL_VSL_TYPE" and "MKL_VSL" directly in my code, rather than as external (I did this to make the code more portable - exe distributed to "non-tech" people so wanted to distribute only a single exe file, with no dependent dll files etc).
The functions "VSLNEWSTREAM" and "VSRNGGAUSSIAN" are definitely are included in "MKL_VSL". I put the two modules in a file called "mkl_vsl.f90". When I do a full rebuild, that file ("mkl_vsl.f90") is the first one to be compiled, so I do not understand why the linker cannot find them.
I do not get the error messages when I compile it as a 32bit app & as mentioned previously, this part of the program was working fine 20 months ago (as a 32bit app).
From what I can deduce from Table 5.3 of the user guide, all I should need for the VSL functions is mkl_core.lib?
Not certain where to go from here :(
TimP
Quoting davidspurr
Perhaps you might consult the link advisor on the head page of this forum?
If you're moving to 64-bit, mkl_core has to be accompanied by the lp64 (if you didn't change source data types from the 32-bit case) or ilp64 library, and either mkl_sequential or mkl_thread plus OpenMP library.
davidspurr
Hmm - just finshed a 4 paragraph note & hit "Submit" only to get an fatal error & lose the lot :(
Just read Tim's post (thanks) - will follow up on that.
davidspurr
Tim, many thanks. the "mkl_intel_lp64.lib" was indeed the missing link !!
But what an exercise, just to change from 32 - 64 bit compile :( ...
Also, thanks for the tip re the link advisor (had not noticed that). Very straightforward - right answer and all !!!
