7303 Discussions
mkl_dcsrcoo documentation: nnz is required input parameter?
bob_edwards
I've noticed a few problems with the documentation of mkl_dcsrcoo, one of which took me a few hours to figure out. The parameter nnz is listed as an output parameter, but I have found that it's value must be set to the number of non-zero elements (the same value assigned to job(5)), or the result is a crash or undefined behavior.
Here is a quick test example in C++:
[cpp]#include "mkl_spblas.h"
#include "mkl_types.h"
#include
using namespace std;
// test matrix A = [1 0]
//                 [0 1]
int main() {
    MKL_INT rowind[2] = {1,2},ia[2],ja[3],job[8] = {1,1,1,0,2,0,0,0};
    MKL_INT info, nnz,n=2;
    double Acoo[2] = {1.0,1.0}, Acsr[2];
    nnz = 0;    // set nnz to a nonsense value before the conversion
    mkl_dcsrcoo (job,&n, Acsr, ja, ia,&nnz,Acoo,rowind,rowind,&info);
    cout << "\n\nAfter passing nnz=0 to mkl_dcsrcoo" << endl;
    cout << "nnz: "  << nnz     << " info: " << info    << endl;
    cout << "ia: "   << ia[0]   << " "       << ia[1]   << endl;
    cout << "Acsr: " << Acsr[0] << " "       << Acsr[1] << endl;
    nnz = 2;   // set nnz to 2
    cout << "\n\nAfter passing nnz=2 to mkl_dcsrcoo" << endl;
[/cpp]
Without the following output:
nnz: 0 info: 0
ia: 1 1
Acsr: 2.65259e-314 2.65259e-314
nnz: 2 info: 0
ia: 1 2
Acsr: 1 1
What I find alarming is that in both instances info = 0 indicating a successful conversion from COO to CSR.
There are other minor missing things in the documentation: mkl_dcsrcoo(job, &n, should be changed too mkl_dcsrcoo(job,&mto match the description, and then the description could be modified to
mINTEGER. Dimension of the matrixA.
m INTEGER. Number of columns of the matrix A
Cheers,
Bob
Gennady_F_Intel
Bob,
we will take into account these comments
Yes, we should to explicitly point that nnz is the input parameter also.
Nevertheless, Looking at the input parameter description we can see..
rowind (input/output)INTEGER. Array of length nnz, contains the row indices for each non-zero element of the matrix A.
--Gennady
pawanlri
Here is a general woking example for a rectangualr matrix
[bash]// This is a routine to check the mkl_csrcoo routine
// for a rectangular matrix, there is a bug in the
// mkl doc, which was pointed out. Here is the working example.
// Matrix is
//      1 0 2 0
// A =  0 0 3 0
//      5 0 7 8
// nnz = 6, m = 3, n = 4
#include
int main(int argc, char *argv[] )
  double acoo[6] ={1., 2., 3., 5., 7., 8.};
  int rowind[6] = {1, 1, 2, 3, 3, 3};
  int colind[6] = {1, 3, 3, 1, 3, 4};
  int m=3, n=4, nnz=6;
  int job[8]={1,1,1,0,6,0,0,0};
  double acsr[6] = {1., 2., 3., 5., 7., 8.};
  int ia[4]; // m+1
  int ja[6];
  int i, info;
  mkl_dcsrcoo(job, &m, acsr, ja, ia, &nnz, acoo, rowind, colind, &info);
  printf("n info = %d n ", info);
  printf("n--- csr matrix ---n");
  printf("n ia = ");
  for(i=0;i);
  printf("n ja = ");
  for(i=0;i);
  printf("n acsr = ");
  for(i=0;i);
  printf("n n");
  return 0;
[/bash]
Hopefully, this helps !
Cheers,
Pawan
