7301 Discussions
mkl_def.so is not found in Intel MKL library 2019
Binay
mkl_def.so is not found in Intel MKL library 2019 or 2020 for linux 32 bit. We have been using using Intel MKL library an older version ( a very old version released sometime in 2012 ) and now trying to upgrade it to latest one. We are finding issue on Linux 32 bit as getting compilation error mkl_def.so ( gcc 6.3 C++ ). We checked and found that the file mkl_def.so is included in Linux 64 bit package but not in Linux 32 bit package of intel MKL. Please suggest how to fix the issue
Gennady_F_Intel
Could you show us how do you link your application on ia32 based system?
JaiKrishna
Could you please let us know that why you guys have removed libmkl_def.so from ia32 ?
We have followed the Intel link line advisor to link our application in 32bit.
Gennady_F_Intel
it is some kind of renaming:
for ia32 IA:  libmkl_p4.so == libmkl_def.so ( the default for SSE@ enabled processors)
therefore your application should migrate to using the latest versions w/o a problem.
for intel64 - yes we provide the same library but with the libmkl_def.so name
