mkl fft3w choosing PRECISION SINGLE OR DOUBLE
Martin_Gumbau
I have installed Intel Composer XE 14.0.2.144.
I can compile fft2w 'single' precision version and 'double' precision version adding  a  compilation parameter:
[PRECISION={MKL_DOUBLE|MKL_SINGLE}]
I do not known how to do the same in fftw3. The make command does not show me this option.
So I do not known how to compile my apps in single or double precision linking mkl fftw3 libraries.
Thanks in advance.
Evarist_F_Intel
Hi, Martin! FFTW3 interface are compiled for both precision at once. Just use fftw_* for double precision or fftwf_* for single precision in your application. Also, please note, that MKL has built-in interface for FFTW3. You can just link your fftw3-application with MKL instead of FFTW3 and it should work (using MKL).
Martin_Gumbau
Great Evarist,
I saw that you say in the code file names in .../mkl/interfaces/fftw3xc/wrapper but I wasn't sure about this.
Now all be clear.
Thanks a lot.
Evarist_F_Intel
You are welcome!
Martin_Gumbau
SOLVED
