7303 Discussions
mkl.fi interfaces are missing some dummy argument definitions
Ben3
Some of the interfaces brought in by mkl.fi are missing some argument definitions. While not an problem, since the implicit typing takes over, it does generate compiler warnings:
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(414): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(427): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(1019): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(1032): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(1623): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(1636): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(2228): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_spblas.fi(2241): warning #6717: This name has not been given an explicit type.
C:\PROGRA~2\INTELS~1\COMPIL~1\windows\mkl\include\mkl_service.fi(251): warning #6717: This name has not been given an explicit type.   [MEM_TYPE]
This is from the 20160121 release. I haven't noticed it before because I don't usually build with /warn:all. Trying to supress them with
!DIR$ NODECLARE
include 'mkl.fi'
!DIR$ DECLARE
doesn't help in this case - I'm guessing the command-line takes precendence.
Cheers,
Ben
Ying_H_Intel
Hi Ben,
thanks for raising this. We will check and update you if any news.
Best Regards
Ying
Ying_H_Intel
Hi Ben,
There is some errors in the mkl header files. We will fix them in later version.
I upload the fix file to you as replacement.
Ying
