mkl_freeBuffer() access violation exception error
mmmmm__hamed
hi
i use mkl c++ compiler 11.0.066 and mkl10.1 and c++/clr vs2008
i use fft and conv function from mkl in multi thread realtime application (each thread exec fft and conv parallel)
but after little time usage memory go up and application crash.
with any leak detector i cant find any leakage in my code .
recently i study mkl help and find i must use mkl_FreeBuffer() after mkl function for avoidance memory leakage
but when i call mkl_freeBuffer Application crash with access violation exception.
what shoud i do?
i use 64 bit mkl
 additional library directory  -> em64t\lib
additional dependecy -> mkl_intel_lp64_dll.lib   ;    mkl_intel_thread_dll.lib     ;  mkl_core_dll.lib
thanks for you.
Bernard
Valued Contributor I
Do you have callstack info?
Judith_W_Intel
This question would probably be more appropriate for the MKL forum not the compiler forum.
https://software.intel.com/en-us/forums/intel-math-kernel-library
Good luck,
Judy
KitturGanesh
I'll transfer this issue to MKL forum so someone from that group can address this accordingly....
_Kittur
Gennady_F_Intel
Can you give us the example of your test which we can compile and check the problem with the latest version of MKL?
or you can try to evaluate the latest updates by yourself.
mmmmm__hamed
this is my code
mkl_complex16*  intelForwardFft (MKL_Complex16* input,int length)
            DFTI_DESCRIPTOR *fft_handle;
           dfticreatedescriptor(&fft_handle,dfti_double,dfti_complex,1,length) ;
           dftisetvalue(fft_handle,dfti_placement,dfti_inplace);
          dfti_computeforward(fft_handle,input);
          dftifreedescriptor(&fft_handle);
          mkl_FreeBuffers();
          return input;     ===>cursor stop here
MKL_Complex16*  Convolution(MKL_Complex16*  x,int   xlength, MKL_Complex16*  y  ,  int ylength )
          int convResLength=xlength+ylength-1;
          VSLCONVTASKPTR   task;
           VSLCONVTASKPTR*   task-ptr;
           int   iy0=0;
           int   *start=&iy0;
           MKL_Complex16* res= (MKL_Complex16*)  malloc(sizeof(MKL_Complex16)  *  convResLength);
           memset( res,  0 ,  sizeof(MKL_Complex16) * ConvResLength );
           int status;
           int   a= vslzConvNewTask1D( task_ptr , VSL_Conv_Mode_Auto , xlength , ylength ,convResLength  );
           int  b = vslzConvSetStart( task  , start);
           status  = vslzConvExec1D( task , x ,1 , y ,1, res , 1 );
           vslconvdeletetask(task_ptr);
           mkl_FreeBuffers();
           return res;
Bernard
>>>but when i call mkl_freeBuffer Application crash with access violation exception>>>
Probably heap corruption or double free.
mmmmm__hamed
Hi iliyapolak my code exist in above comment . no double free.
only function Result ( res variable ) will be released after use.
are you have idea?
Bernard
Without the callstack of crash is very hard to tell what has happend
