mkl_?imatcopy
soliton
Hi All,
Has anyone had any experience on using the in place traspose/scale routines mkl_?imatcopy?
I have been trying to make it work in my code but it always returns the matrix untouched.
I am using mkl 10.1 from a fortran program.
my simple test code is:
a1(1,1) = 1.0_8
a1(1,2) = 3.0_8
a1(2,2) = 5.0_8
a1(2,1) = 7.0_8
call dimatcopy(C,T,2,2,5.0_8,a1,2,2)
write(*,*)a1(1,1)
write(*,*)a1(1,2)
write(*,*)a1(2,2)
write(*,*)a1(2,1)
which writes back the values without change.
Cheers,
Cristian
Vladimir_Petrov__Int
New Contributor III
Quoting - soliton
Hi All,
a1(1,1) = 1.0_8
a1(1,2) = 3.0_8
a1(2,2) = 5.0_8
a1(2,1) = 7.0_8
write(*,*)a1(1,1)
write(*,*)a1(1,2)
write(*,*)a1(2,2)
write(*,*)a1(2,1)
Cheers,
Cristian
Cristian,
This is a problem in the FORTRAN interface of the matrix movement routines which will be fixed in our future releases. In case you urgently need the fix I would recomend submitting this to the premier.intel.com site.
Vladimir
soliton
Quoting - soliton
Hi All,
a1(1,1) = 1.0_8
a1(1,2) = 3.0_8
a1(2,2) = 5.0_8
a1(2,1) = 7.0_8
write(*,*)a1(1,1)
write(*,*)a1(1,2)
write(*,*)a1(2,2)
write(*,*)a1(2,1)
Cheers,
Cristian
Cristian,
Vladimir
Thanx Vladimir,
The problem seems to be there for all of the "blas like extensions" routines Ive tried. Do you know wether the C ones work fine? If thats the case I might write a small C wrapper to get the job done.
Cheers,
Cristian
New Contributor III
Cristian,
Yes, the C interface works correctly.
Vladimir
Gennady_F_Intel
FYI: Below - the output of your code:
a[0] == 1.000000
a[1] == 3.000000
a[2] == 5.000000
a[3] == 7.000000
C interface of mkl_dimatcopy
OUTPUT DATA
a[0] == 5.000000
a[1] == 25.000000
a[2] == 15.000000
a[3] == 35.000000
Press any key to continue .
--Gennady
soliton
a[0] == 1.000000
a[1] == 3.000000
a[2] == 5.000000
a[3] == 7.000000
OUTPUT DATA
a[0] == 5.000000
a[1] == 25.000000
a[2] == 15.000000
a[3] == 35.000000
--Gennady
Many thanx Guys,
Ive managed to make a tiny C wrapper for the routines I needed and it works fine. Code for a rudimentary working interface to zomatadd is attached. Its probably not "correct" since my C is extremely rudimentary.
All the best,
Cristian
#include
#include "mkl_trans.h"
void matadd_(int *d, MKL_Complex16 *a, MKL_Complex16 *alpha, MKL_Complex16 *b, MKL_Complex16 *beta, MKL_Complex16 *c)
unsigned long dim;
dim = *d;
mkl_zomatadd('C','N','N',dim,dim,*alpha,a,dim,*beta,b,dim,c,dim);
Gennady_F_Intel
Quoting - soliton
Thanx Vladimir,
Cheers,
Cristian
Cristian,
the problem with this routine ( Fortran interfaces ) was fixed in MKL version 10.2. released yesterday.
This version available for download from intel registration center: https://registrationcenter.intel.com/
one comment:
use parameter fomat 5.0d1 instead of 5.0
mkl_dimatcopy( 'C','T', 2, 2, 5.0d1, a, 2, 2)
see below the output i received with your test:
THE In-place transposition/copying of matrices
500.000000000000
3500.00000000000
2500.00000000000
1500.00000000000
THE Out-place transposition/copying of matrices
25000.0000000000
75000.0000000000
125000.000000000
175000.000000000
THE END
Press any key to continue . . .
Regards, Gennady
