mkl linking problem
e_shahraeeni
I have a strange problem. using MKL for linear solver, I had no problem to link MKL to my code in visual studio. Now under mac when I try to compile the exact same code with make file, I get error message
Obj/mod_diffusion.o Obj/mod_time.o gas.f90 -c -module Mod/ -o Obj/gas.o
Solver/linear_solver_RCIISS.f90(13): error #5102: Cannot open include file 'mkl_rci.fi'
INCLUDE 'mkl_rci.fi'
compilation aborted for gas.f90 (code 1)
The MKL include directory is defined in the make file as:
MKLROOT = /opt/intel/composer_xe_2011_sp1.9.289/mkl/
MKL = -I$(MKLROOT)/include/intel64/lp64 -I$(MKLROOT)/include -L$(MKLROOT)/lib $(MKLROOT)/lib/libmkl_blas95_lp64.a $(MKLROOT)/lib/libmkl_lapack95_lp64.a -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -openmp -lpthread -lm
and the file is there (/opt/intel/composer_xe_2011_sp1.9.289/mkl/include/mkl_rci.fi)
I even add the file 'mkl_rci.fi' directly to the project, but it gives me the same error. I used other MKL functions before the recent changes in the project and there was no problem in linking and compiling. Any clue what would be the problem?
Ebrahim
mecej4
I am not familiar with the Macintosh MKL setup, but I notice this discrepancy:
You specified
but the particular include file is not target-architecture specific, and is therefore located in
$(MKLROOT)/include
e_shahraeeni
I supposed there is no difference between:
and
MKL = -I$(MKLROOT)/include -I$(MKLROOT)/include/intel64/lp64
but there is!
Following your advice by using the second one, now I get new error:
Undefined symbols for architecture x86_64:
"_linear_solver_rciiss_", referenced from:
_MAIN__ in gas.o
ld: symbol(s) not found for architecture x86_64
make: *** [FRSGW3D.e] Error 1
Lorri_M_Intel
And now, what command are you using to link the final executable?
It appears you are not including the mkl libraries.
there is a command line switch that will add the libraries for you:
ifort -mkl gas.o -o gas
--Lorri
