mkl_pardiso_pivot
nedialk
It is not clear from the documentation of mkl_pardiso_pivot: do I have to write the body of this function and compile it with my code? Is there any example showing how this function is used?
Ned
MRajesh_intel
Thanks for posting your query.
>>Do I have to write the body of this function and compile it with my code?
Yes, you can write a body of the function to specify the values.
Rajesh.
MRajesh_intel
Rajesh.
Kirill_V_Intel
Hi Ned,
There is an example for using mkl_pardiso_pivot. See pardiso_sym_diag_pivot.c in examples/c/sparse_directsolvers if you have one of the latest oneMKL releases. If you don't have examples/c/sparse_directsolvers, look in examples/c/solversc.
Best,
Kirill
MRajesh_intel
Thanks for accepting as a Solution.
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh
