mkl routine slasrt2
LeonardB
Hi
I've a program that is calling the mkl routine slasrt successfully by
call slasrt('I', nr, rvek, info)
When changing to slasrt2 by
call slasrt2('I', nr, rvek, isort, info)
the linker reports:
Error 1  error LNK2019: unresolved external symbol _SLASRT2 referenced in function _MAKERZPLANE makePlane.obj
Compiler=Compose XE 2013 SP1, and I am using visual studio 2010 with Configuration properties -Fortran - Libraries- Use Intel Math Kernel Library set to sequential((/Qmkl:sequential)
What's wrong?
mecej4
That routine (SLASRT2) is included in Scalapack. Use the Link Line Advisor (either your locally installed version or the one here:  http://software.intel.com/sites/products/mkl/MKL_Link_Line_Advisor.html) to select the proper Scalapack library to use in your link step. With some of the more recent versions of MKL, Scalapack support for IA32 appears to have been withdrawn.
mecej4
