mkl_sequential.2.dll was not found
Ever
My Fortran code uses MKL, it can compile and build as both Debug x64 and Debus x86, but when execute it, I get "mkl_sequential.2.dll was not found."
This question was posted in 2021, that thread is closed to community only, but this is obviously a NEW bug, I just installed the latest version.
I installed OneAPI with MKL yesterday with MKL but just in case today I went to "modify", but it is there, so I went to "repair", and let it "repair". No luck.
My code was developed in the period ending in 2018 with Intel parallel studio, and it worked.
We used a .obj to distribute it.
That .obj still works on this installations that have Intel parallel studio.
What can I do?
Ever
Further I wrote a test program that actually does not call any MKL, but in VS>Project properties>Fortran>Libraries I set use Intel Math Kernel Library>/Qmkl:sequential for all platforms.
When I run is as x64, it works, the dummy program just pauses for me to hit Enter.
When I run it as x86, I get "fatal error LNK1104: cannot open file 'mkl_intel_c_dll.lib'"
Note that I already went to VS>Tools>Options> Intel libraries for oneAPI, and I checked oneMKL 2023.1.0 for both x64 and x86.
What else can I do?
ShanmukhS_Intel
Hi Ever Barbero,
Could you please check the below path for mkl_sequential.2.dll. If not, could you please try uninstalling and installing the oneAPI toolkit and let us know if the issue persists?
C:\Program Files (x86)\Intel\oneAPI\mkl\2023.1.0\redist\intel64\
Shanmukh.SS
ShanmukhS_Intel
A gentle reminder:
Has the information provided helped? Kindly let us know if you were able to get the mkl_sequential.2.dll in the shared path.
Shanmukh.SS
