mkl_sequential.dll was not found
veronlk
I am trying to run a program that needs Intel Fortran redistributable package to run: "FAST.Farm_x64_OMP.exe is built with OpenMP libraries and linked with dynamic libraries.
You will need this Intel Fortran redistributable package installed to run FAST.Farm_x64_OMP.exe if you do not already have Intel Fortran 2019 Update 5 installed. See the installation instructions here. You may also need a redistributable library for Visual Studio installed"
I have installed the necessary redistributables, but when I try to run the program, I get the following message: "The code execution cannot proceed because mkl_sequential.dll was not found. Reinstalling the program may fix this problem".
I have tried to reinstall the oneAPI base toolkit and the HPC toolkit, but it doesn't help. As far as I understand, the oneAPI toolkit includes the math kernel library. I am new to using Intel.
VidyalathaB_Intel
Hi Veronica,
Could you please let us know if you have enabled /Qmkl option under
Configuration properties > Fortran > Libraries > Use Intel MKL > select required options from the drop-down?
Here is a thread with a similar discussion that might help you in resolving the issue.
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/mkl-intel-thread-1-dll-was-not-found/m-p/1287801#M31470
Vidya.
VidyalathaB_Intel
Hi Veronica,
As we haven't heard back from you, could you please provide us with an update regarding the issue?
Vidya.
VidyalathaB_Intel
Hi Veronica,
As we haven't heard back from you, we are closing this thread. Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Vidya.
