7298 Discussions
mkl_sparse_sypr for symmetric (Non-Hermitian) complex matrices
Razmo86
I need to compute the symmetric product of three sparse matrices (D=P'AP) using the mkl_sparse_sypr routine, however I am not able to get the correct results. In my case, the P matrix is a general type real matrix, and the matrix A is a symmetric complex matrix. For example, consider the below matrices and their corresponding 3-array CSR format (for matrix A only the upper triangle is stored):
For matrix A, I created the CSR matrix and its descriptor as shown below:
Similarly, for matrix P, it is defined as a general type matrix. Here I declared the REAL matrix P as a complex matrix ( the imaginary part of all the nonzero entries are set to zero):
Finally, the below code is used to perform the symmetric product in a single computation stage. I also export the CSR results in order to validate the entries of the resultant symmetric matrix D.
The resultant matrix D has a correct sparsity pattern, however, in this example, two entries doesn't have a correct value (see highlighted below). The correct values are -4+12i and 2+12i, respectively.
I observed the same issue once I tried to compute the PAP' using the SPARSE_OPERATION_NON_TRANSPOSE operation. The results appear to be correct for the cases where both A and P matrices are real.
Is mkl_sparse_sypr routine only applicable to Hermitian complex  matrix A ?  Can it be applied to symmetric complex matrix A?
Gennady_F_Intel
This routine (C:=A*B*opA(A) ) is applicable if A has a general structure, B and C are symmetric or Hermitian matrices.  We don't know the issue wrt this routine in the current version of MKL. if you observe some problem - I would recommend give us the reproducer which we could compile and run on our end.
Razmo86
@Gennady_F_Intel  Thank you for looking into this issue.
! Consider the matrix A
!                 |   1       -1+3i   0   -3+6i  0   |
!                 |  -1+3i     5      0    0     8   |
!   A    =        |   0        0      4    6     4   |,
!                 |  -3+6i     0      6    7     0   |
!                 |   0        8      4    0    -5   |
!  The matrix A is represented in a one-based compressed sparse row (CSR) storage
!  scheme with three arrays: Only the upper triangular part is stored
!         values  = ( 1 -1+3i -3+6i 5 8 4 6 4 7 -5 )
!         columns = ( 1 2 4 2 5 3 4 5 4 5 )
!         rowIndex = ( 1 4 6 9 10 11 )
!                 |   1        0      0       1      0   |
!                 |   0        0      4       0      0   |
!   P    =        |   0.5      0      0       0      0   |,
!                 |   0        0      0       1      0   |
!                 |   0     -6.5      0       0      1   |
!         values  = ( 1 1 4 0.5 1 -6.5 1 )
!         columns = ( 1 4 3 1 4 2 5 )
!         rowIndex = ( 1 3 4 5 6 8 )
!  The test performs the following operations :
!  The test performs the following operation :
!  The code computes D = P'AP using mkl_sparse_sypr. P is a MXM General
  sparse matrix
!       where A is a symmetric sparse matrix where only the upper triangular part is stored
PROGRAM TestSPBLASProgram
    USE MKL_SPBLAS
    USE ISO_C_BINDING
    IMPLICIT NONE
    INTEGER M, N, NNZ,NNZP, i, info,j
!   Sparse representation of the matrix A and P
    INTEGER, ALLOCATABLE :: csrColInd(:), csrRowPtr(:),csrPColInd(:), csrPRowPtr(:)
    COMPLEX*16, ALLOCATABLE :: csrVal(:),csrPVal(:)
!   Matrix descriptor
    TYPE(MATRIX_DESCR) descrA,descrP,descrD     ! Sparse matrix descriptor
!   CSR matrix representation
    TYPE(SPARSE_MATRIX_T) csrA,csrP,csrD        ! Structure with sparse matrix
!   Declaration of local variables:
    INTEGER :: nCol,nrowsD, ncolsD
    INTEGER(C_INT) :: indexing
    TYPE(C_PTR)    :: rowsD_start, rowsD_end, colD_indx, Dvalues
    INTEGER   , POINTER :: rowsD_start_f(:), rowsD_end_f(:), colD_indx_f(:)
    COMPLEX*16, POINTER :: Dvalues_f(:)
    NNZ = 10
    ALLOCATE(csrColInd(NNZ))
    ALLOCATE(csrRowPtr(M+1))
    ALLOCATE(csrVal(NNZ))
    csrVal = (/(1.0D0,0.0D0), (-1.0D0,3.0D0) ,(-3.0D0,6.0D0), (5.0D0,0.0D0) ,(8.0D0,0.0D0) ,(4.0D0,0.0D0) ,(6.0D0,0.0D0), (4.0D0,0.0D0), (7.0D0,0.0D0), (-5.0D0,0.0D0)/)
    csrColInd = (/ 1, 2, 4, 2, 5, 3, 4, 5, 4, 5 /)
    csrRowPtr = (/1, 4, 6, 9, 10, 11/)
    M = 5
    N = 5
    NNZP = 6
    ALLOCATE(csrPColInd(NNZP))
    ALLOCATE(csrPRowPtr(M+1))
    ALLOCATE(csrPVal(NNZP))
    csrPVal = (/(1.0D0,0.0D0),(1.0D0,0.0D0) ,(4.0D0,0.0D0) ,(0.5D0,0.0D0),(1.0D0,0.0D0) ,(-6.5D0,0.0D0) ,(1.0D0,0.0D0)/)
    csrPColInd = (/1 ,4 ,3 ,1 ,4 ,2 ,5 /)
    csrPRowPtr = (/1 ,3 ,4 ,5 ,6 ,8 /)
    print*,'EXAMPLE PROGRAM FOR mkl_sparse_sypr'
    print*,'--------------------------------------------------------'
!   Create CSR matrix A
    i = MKL_SPARSE_Z_CREATE_CSR(csrA,SPARSE_INDEX_BASE_ONE,M,N,csrRowPtr,csrRowPtr(2),csrColInd,csrVal)
!   Create matrix descriptor
    !descrA % TYPE = SPARSE_MATRIX_TYPE_GENERAL
    descrA % TYPE = SPARSE_MATRIX_TYPE_SYMMETRIC
    descrA % MODE = SPARSE_FILL_MODE_UPPER
    descrA % DIAG = SPARSE_DIAG_NON_UNIT
!   Analyze sparse matrix; chose proper kernels and workload balancing strategy
    info = MKL_SPARSE_OPTIMIZE(csrA)
!   Create CSR matrix P
    i = MKL_SPARSE_Z_CREATE_CSR(csrP,SPARSE_INDEX_BASE_ONE,M,N,csrPRowPtr,csrPRowPtr(2),csrPColInd,csrPVal)
    descrP % TYPE = SPARSE_MATRIX_TYPE_GENERAL
    info = MKL_SPARSE_OPTIMIZE(csrP)
    ! Single Stage Computations
    info = mkl_sparse_sypr (SPARSE_OPERATION_CONJUGATE_TRANSPOSE, csrP, csrA, descrA, csrD, SPARSE_STAGE_FULL_MULT)
! export the matrix D in CSR format matrix from the internal representation
    info = mkl_sparse_z_export_csr (csrD, indexing, nrowsD, ncolsD, rowsD_start, rowsD_end, colD_indx, Dvalues)
    info = mkl_sparse_order(csrD)
!   Converting C into Fortran pointers
    call C_F_POINTER(rowsD_start, rowsD_start_f, [nrowsD])
    call C_F_POINTER(rowsD_end  , rowsD_end_f  , [nrowsD])
    call C_F_POINTER(colD_indx  , colD_indx_f  , [rowsD_end_f(nrowsD)-indexing])
    call C_F_POINTER(Dvalues    , Dvalues_f    , [rowsD_end_f(nrowsD)-indexing])
!   Release internal representation of CSR matrix
    info = MKL_SPARSE_DESTROY(csrA)
    info = MKL_SPARSE_DESTROY(csrP)
    info = MKL_SPARSE_DESTROY(csrD)
END PROGRAM TestSPBLASProgram
Razmo86
@Gennady_F_Intel Thanks for looking into this issue. Here is the test program:
!                 |  -1+3i     5      0    0     8   |
!                 |  -3+6i     0      6    7     0   |
!                 |   0        8      4    0    -5   |
!                 |   1        0      0       1      0   |
!                 |   0        0      4       0      0   |
!                 |   0        0      0       1      0   |
!                 |   0     -6.5      0       0      1   |
!       The code computes D = P'AP using mkl_sparse_sypr. P is a MXM General sparse matrix
    USE MKL_SPBLAS
    USE ISO_C_BINDING
    IMPLICIT NONE
!   Matrix descriptor
    NNZ = 10
    M = 5
    N = 5
    NNZP = 6
Kirill_V_Intel
Hi!
I'm pretty sure the reason for what you see is a misleading wording in documentation. Routine mkl_sparse_sypr supports symmetric matrices A for real data types and hermitian (only) A for complex case [while the docs say "B and C are symmetric or Hermitian matrices" as if symmetric works for complex matrices].
E.g., a quick implicit proof: if you change
to
descrA % TYPE = SPARSE_MATRIX_TYPE_HERMITIAN
you'll get same result. I haven't checked but I believe that is the correct result if matrix A is treated as Hermitian [let me know if you think this is incorrect].
If you need this functionality, our TCE can help you submit a FR, so that we can extend mkl-sparse_sypr to work for your case (should be straightforward).
Best,
Kirill
Razmo86
@Kirill_V_Intel Thanks for your answer. Correct, I have already verified that the routine is working correctly for real symmetric and Hermitian complex matrices. It would be great if you could extend mkl-sparse_sypr to symmetric complex matrices as well. Would you please let me know how I should process with the FR submission?
Gennady_F_Intel
Razmo, the official channel to submit the Feature Request to the Intel Online Service Center - https://supporttickets.intel.com/servicecenter?lang=en-US
Gennady_F_Intel
Intel oneAPI Math Kernel Library (oneMKL) version 2021.4 is now available. The MKL Developer Reference has been updated.
Gennady_F_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
