mkl_sparse_?_update_values seems not to work
Meng__Xiangyi
I have constructed a sparse matrix in BSR format and try to use the function mkl_sparse_?_update_values to update some values, but it seems that the updated matrix doesn't change the value, dose anybody meet the  same problem as me?
Meng__Xiangyi
This is my test code
program main
use mkl_spblas
use iso_c_binding
implicit none
type(SPARSE_MATRIX_T) A, B
type(MATRIX_DESCR) descA
integer :: indexing = SPARSE_INDEX_BASE_ONE
integer :: block_layout = SPARSE_LAYOUT_COLUMN_MAJOR
integer nrows, ncols, block_size, block_size2, nblocks
integer, allocatable :: row_ptr(:), col_indx(:)
real(8), allocatable :: values(:)
type(c_ptr) rows_start_c, rows_end_c, col_indx_c, values_c
integer, pointer :: rows_start_f(:), rows_end_f(:), col_indx_f(:)
real(8), pointer :: values_f(:)
integer stat, i, j
integer :: nvalues = 3, indx(3) = (/3, 5, 6/), indy(3) = (/3, 4, 6/)
real(8) :: values_(3) = (/2.d0, 2.d0, 2.d0/)
nrows = 3
ncols = 3
block_size = 2
block_size2 = block_size * block_size
nblocks = 5
allocate(row_ptr(nrows + 1))
allocate(col_indx(nblocks))
allocate(values(block_size2 * nblocks))
row_ptr = (/ 1, 3, 4, 6 /)
col_indx = (/ 1, 2, 2, 2, 3 /)
values = (/ 1.d0, 2.d0, 0.d0, 1.d0, 6.d0, 8.d0, 7.d0, 2.d0, 1.d0, 5.d0, 4.d0, 1.d0, 4.d0, 0.d0, 3.d0, 0.d0, 7.d0, 0.d0, 2.d0, 0.d0 /)
print *, '---------------------------------------------------'
do i = 1, nrows
print '(1x, a, i2, a)', '-------------block row #', i, '--------------'
do j = row_ptr(i), row_ptr(i + 1) - 1
print '(1x, a, i2)', 'block column #', col_indx(j)
print '(<block_size>f6.2)', transpose(reshape(values((j - 1) * block_size2 + 1 : j * block_size2), (/block_size, block_size/)))
end do
end do
stat = mkl_sparse_d_create_bsr(A, indexing, block_layout, nrows, ncols, block_size, row_ptr, row_ptr(2), col_indx, values)
stat = mkl_sparse_d_update_values(A, nvalues, indx, indy, values_)
stat = mkl_sparse_d_export_bsr(A, indexing, block_layout, nrows, ncols, block_size, rows_start_c, rows_end_c, col_indx_c, values_c)
call c_f_pointer(rows_start_c, rows_start_f, [nrows])
call c_f_pointer(rows_end_c , rows_end_f , [nrows])
call c_f_pointer(col_indx_c , col_indx_f , [rows_end_f(nrows) - 1])
call c_f_pointer(values_c , values_f , [block_size2 * nblocks])
do i = 1, nrows
do j = rows_start_f(i), rows_end_f(i) - 1
print '(<block_size>f6.2)', transpose(reshape(values_f((j - 1) * block_size2 + 1 : j * block_size2), (/block_size, block_size/)))
end do
end do
end program main
and this is the output
 -------------block row # 1--------------
 block column # 1
  1.00  0.00
  2.00  1.00
 block column # 2
  6.00  7.00
  8.00  2.00
 -------------block row # 2--------------
 block column # 2
  1.00  4.00
  5.00  1.00
 -------------block row # 3--------------
 block column # 2
  4.00  3.00
  0.00  0.00
 block column # 3
  7.00  2.00
  0.00  0.00
 block column # 1
  1.00  0.00
  2.00  1.00
 block column # 2
  6.00  7.00
  8.00  2.00
 block column # 2
  1.00  4.00
  5.00  1.00
 block column # 2
  4.00  3.00
  0.00  0.00
 block column # 3
  7.00  2.00
  0.00  0.00
MariaZh
Can you please check the returned status of the routine and provide a reproducer for your case?
Maria
Meng__Xiangyi
Maria
Thank you for your reply, after calling 'stat = mkl_sparse_d_update_values(A, nvalues, indx, indy, values_)', the value of 'stat' is 6, which is associated with SPARSE_STATUS_NOT_SUPPORTED, is there anything wrong with my arguments?
And another question, when I want to update all the values in the matrix, how can I give the arguments? As all the arguments are not declared optional, how can I ignore 'indx' and 'indy' as Reference Developer said?
MariaZh
Updating the selected values of the matrix is not supported currently.
If you want to update the values of the full matrix, you just need to pass NULL for indx and indy.
Hope this helps!
Maria
