negative eigen vector
baha_tr
I use the dsyevx library when calculating eigenvalues ​​and eigenvectors in a two-dimensional matrix, but the values ​​of the eigenvector (negative wave function) are negative. What is the reason?
Ruqiu_C_Intel
It's hard to say what's the reason for your issue without checking your code. Attached dsyevx example for your reference.
baha_tr
Unfortunately, when I tried to solve 2D eigenvectors, the library founds  the wave functions negative.
Chao_Y_Intel
Hi,  do you have a reproducible code that can help investigate this problem?
thanks,
Chao
