7303 Discussions
omp warning when using pardiso and metis threaded version
may_ka
when running pardiso and setting iparm[1]=3 (C interface) I get the warning message:
OMP: Warning #97: Requested number of active parallel levels "-2147483648" is negative; ignored
The relevant omp setting is "OMP_MAX_ACTIVE_LEVELS=2147483647", which should be perfectly fine for a 32-bit integer.
Mkl version is oneapi 2021-2, operation system linux. The mkl interface is ilp64.
Any idea?
Best
Gennady_F_Intel
Which OpenMP threading do you use? checking with mkl_intel_thread.so linked with the testing examples (mkl 2022), I see no such messages.
may_ka
Hi
the link line is:
-Wl,--start-group \
	/opt/oneapi/mkl/2021.2.0/lib/intel64/libmkl_intel_ilp64.a \
	/opt/oneapi/mkl/2021.2.0/lib/intel64/libmkl_core.a \
	/opt/oneapi/mkl/2021.2.0/lib/intel64/libmkl_intel_thread.a -l iomp5 -l pthread -lm -ldl \
	-Wl,--end-group
Gennady_F_Intel
what is the matrix type?
Checking the problem right now with -2 matrix type on the real workload, I see no problems here.
may_ka
The matrix type is 2 (real and symmetric positive definite), and iparm[1]=3 (C-Interface, ".. The parallel (OpenMP) version of the nested dissection algorithm..")
Gennady_F_Intel
Karl,
checking with mtype=2. I have had no success reproducing:
icc --version : icc (ICC) 2021.5.0 20211109
echo $MKLROOT : /opt/intel/oneapi/mkl/2022.0.2
We need the test to go further.
may_ka
thank's for the update.
I use g++
g++ --version
g++ (GCC) 11.2.0
 Compiling a stand-alone executable which calls pardiso with this
g++ -O3 -std=c++20 -c main.cpp -o main.o  -I /opt/intel/oneapi/mkl/2021.2.0/include/intel64/ilp64 -I /opt/intel/oneapi/mkl/2021.2.0/include/
g++ -static -L /opt/intel/oneapi/compiler/2021.2.0/linux/compiler/lib/intel64_lin -o exe main.o -Wl,--start-group /opt/intel/oneapi/mkl/2021.2.0/lib/intel64/libmkl_intel_ilp64.a /opt/intel/oneapi/mkl/2021.2.0/lib/intel64/libmkl_core.a /opt/intel/oneapi/mkl/2021.2.0/lib/intel64/libmkl_intel_thread.a -l iomp5 -l pthread -lm -ldl -Wl,--end-group
/usr/bin/ld: /opt/intel/oneapi/mkl/2021.2.0/lib/intel64/libmkl_core.a(mkl_memory_patched.o): in function `mkl_serv_set_memory_limit':
mkl_memory.c:(.text+0x5d1): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
 and this omp setting:
printenv | egrep "OMP|KMP"
OMP_PLACES=cores
OMP_PROC_BIND=true
OMP_DYNAMIC=FALSE
KMP_AFFINITY=granularity=core,scatter
OMP_NUM_THREADS=18
OMP_STACKSIZE=2000M
 produces this screen output:
OMP: Warning #182: OMP_PLACES: ignored because KMP_AFFINITY has been defined
OMP: Warning #182: OMP_PROC_BIND: ignored because KMP_AFFINITY has been defined
OMP: Warning #97: Requested number of active parallel levels "-2147483648" is negative; ignored.
Hope this helps.
may_ka
thanks for looking into this.
I am using g++
g++ --version
g++ (GCC) 11.2.0
 an executable calling pardiso, when compiled and linked with
 running with environment variables
printenv | egrep "OMP|KMP|MKL"
OMP_PLACES=cores
OMP_PROC_BIND=true
OMP_DYNAMIC=FALSE
MKLROOT=/opt/intel/mkl
OMP_NUM_THREADS=18
OMP_STACKSIZE=2000M
MKL_NUM_THREADS=18
 produces these massages:
Hope that helps.
