7303 Discussions
oneAPI 2025.0 (MKL): My code does not build any more
rbunger
New Contributor II
I have been able to build my code using oneAPI 2024.2 and earlier. Now with oneAPI 2025.0 it does not build any more. I do not have a minimal running example or similar... I just know that I was able to build with 2024.2 and now I get multiple errors. I call the oneAPI via the Eigen library.
I have tried with CXX=icpx and CXX=g++.
Rainer
$HOME/intel.2025.0/oneapi/mkl/2025.0/include/mkl_direct_call.h:740:69: error: invalid conversion from ‘const void*’ to ‘const MKL_Complex16*’ {aka ‘const _MKL_Complex16*’} [-fpermissive]
740 | fname_unrolledc((side), (uplo), (transa), (diag), (m), (n), (const void *)(alpha), (const void *)(a), (lda), (void *)(b), (ldb)); \
| const void*
$HOME/intel.2025.0/oneapi/mkl/2025.0/include/mkl_direct_call.h:763:71: note: in expansion of macro ‘MKL_DC_TRSM_CONVERT’
763 | #define ztrsm(side, uplo, transa, diag, m, n, alpha, a, lda, b, ldb) MKL_DC_TRSM_CONVERT(side, uplo, transa, diag, m, n, alpha, a, lda, b, ldb, mkl_dc_ztrsm, ztrsm_direct)
Aleksandra_K
I'm sorry for making the confusion - by the next release, I meant the next standard release 2025.1, not 2025.0.1.
Aleksandra
Aleksandra_K
Dear Rainer,
I have reproduced the issue using my sample code. It appeared that the problem probably is due to changes in the header file mkl_direct_call.h compared to earlier versions.
I have escalated this issue to our development team for further investigation and resolution.
Aleksandra
rbunger
New Contributor II
Aleksandra_K
Hello Rainer,
I wanted to let you know that our developers have looked into the issue and confirmed that it will be fixed in the next release.
Thank you for notifying us about the issue.
Aleksandra
rbunger
New Contributor II
Hi Aleksandra,
happy new year
There is a "next release" available (2025.0.1, Dec. 11 2024) so I tried that one in order to check if the problems building my code are gone. They are not, I get tons of errors (see below for the first few I encountered). Sorry again for not providing a MWE... As mentioned above, I'm am able to build with 2024.2.1...
Thanks for your efforts & kind regards
Rainer
home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h:163:1: error: no matching function for call to 'mkl_dc_daxpy'
163 | EIGEN_BLAS_TRMV_CM(double, double, d, d, )
/home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h:134:7: note: expanded from macro 'EIGEN_BLAS_TRMV_CM'
134 | BLASPREFIX##axpy##BLASPOSTFIX(&n, (const BLASTYPE*)&numext::real_ref(alpha), (const BLASTYPE*)x, &incx, \
135 | (BLASTYPE*)res_, &incy); \
<scratch space>:59:1: note: expanded from here
59 | daxpy
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:834:111: note: expanded from macro 'daxpy'
834 | #define daxpy(n,alpha,x,incx,y,incy) MKL_DC_AXPY_CONVERT(n, alpha, x, incx, y, incy, MKL_DC_DAXPY_CHECKSIZE, mkl_dc_daxpy, daxpy_direct)
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:827:9: note: expanded from macro 'MKL_DC_AXPY_CONVERT'
827 | fname_unrolledc((n), (const void *)(alpha), (const void *)(x), (incx), (void *)(y), (incy));\
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_blas.h:892:22: note: candidate function not viable: cannot convert argument of incomplete type 'const void *' to 'const double *' for 2nd argument
892 | static __inline void mkl_dc_axpy (const MKL_INT *N, const mkl_dc_type *ALPHA, const mkl_dc_type *x, const MKL_INT *INCX, mkl_dc_type *y, const MKL_INT *INCY)
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_blas.h:30:21: note: expanded from macro 'mkl_dc_axpy'
30 | #define mkl_dc_axpy mkl_dc_daxpy
home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h:163:1: error: no matching function for call to 'daxpy_direct'
59 | daxpy
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:834:125: note: expanded from macro 'daxpy'
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:830:9: note: expanded from macro 'MKL_DC_AXPY_CONVERT'
830 | fname_direct((n), (const void *)(alpha), (const void *)(x), (incx), (void *)(y), (incy), &mkl_direct_call_flag); \
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:96:6: note: candidate function not viable: cannot convert argument of incomplete type 'const void *' to 'const double *' for 2nd argument
96 | void daxpy_direct(const MKL_INT *n, const double *alpha, const double *x, const MKL_INT *incx, double *y, const MKL_INT *incy, const MKL_INT* flag);
/home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h:164:1: error: no matching function for call to 'mkl_dc_zaxpy'
164 | EIGEN_BLAS_TRMV_CM(dcomplex, MKL_Complex16, cd, z, )
<scratch space>:63:1: note: expanded from here
63 | zaxpy
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:846:111: note: expanded from macro 'zaxpy'
846 | #define zaxpy(n,alpha,x,incx,y,incy) MKL_DC_AXPY_CONVERT(n, alpha, x, incx, y, incy, MKL_DC_ZAXPY_CHECKSIZE, mkl_dc_zaxpy, zaxpy_direct)
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_blas.h:892:22: note: candidate function not viable: cannot convert argument of incomplete type 'const void *' to 'const MKL_Complex16 *' (aka 'const _MKL_Complex16 *') for 2nd argument
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_blas.h:52:21: note: expanded from macro 'mkl_dc_axpy'
52 | #define mkl_dc_axpy mkl_dc_zaxpy
/home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h:166:1: error: no matching function for call to 'caxpy_direct'
166 | EIGEN_BLAS_TRMV_CM(scomplex, MKL_Complex8, cf, c, )
<scratch space>:71:1: note: expanded from here
71 | caxpy
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:842:125: note: expanded from macro 'caxpy'
842 | #define caxpy(n,alpha,x,incx,y,incy) MKL_DC_AXPY_CONVERT(n, alpha, x, incx, y, incy, MKL_DC_CAXPY_CHECKSIZE, mkl_dc_caxpy, caxpy_direct)
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:98:6: note: candidate function not viable: cannot convert argument of incomplete type 'const void *' to 'const MKL_Complex8 *' (aka 'const _MKL_Complex8 *') for 2nd argument
98 | void caxpy_direct(const MKL_INT *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const MKL_INT *incx, MKL_Complex8 *y, const MKL_INT *inc, const MKL_INT* flag);
/home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h:91:35: error: no matching function for call to 'dtrsm_direct'
91 | EIGEN_BLAS_TRSM_L(double, double, dtrsm)
/home/bunger/MLFMM-2G/trunk/Source/../Third-Party-Libraries/eigen3/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h:85:7: note: expanded from macro 'EIGEN_BLAS_TRSM_L'
85 | BLASFUNC(&side, &uplo, &transa, &diag, &m, &n, (const BLASTYPE*)&numext::real_ref(alpha), (const BLASTYPE*)a, \
86 | &lda, (BLASTYPE*)_other, &ldb); \
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:748:160: note: expanded from macro 'dtrsm'
748 | #define dtrsm(side, uplo, transa, diag, m, n, alpha, a, lda, b, ldb) MKL_DC_TRSM_CONVERT(side, uplo, transa, diag, m, n, alpha, a, lda, b, ldb, mkl_dc_dtrsm, dtrsm_direct)
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:743:9: note: expanded from macro 'MKL_DC_TRSM_CONVERT'
743 | fname_direct((side), (uplo), (transa), (diag), (m), (n), (const void *)(alpha), (const void *)(a), (lda), (void *)(b), (ldb), &mkl_direct_call_flag); \
/home/bunger/intel/oneapi/mkl/2025.0/include/mkl_direct_call.h:85:6: note: candidate function not viable: cannot convert argument of incomplete type 'const void *' to 'const double *' for 7th argument
85 | void dtrsm_direct(const char *side, const char *uplo, const char *transa, const char *diag, const MKL_INT *m, const MKL_INT *n, const double *alpha, const double *a, const MKL_INT *lda, double *b, const MKL_INT *ldb, const MKL_INT* flag);
nepacheo
Given the issue hasn't been fixed yet, is it possible to get access to the 2024.2.2 release? I can't find any way to download it from the website, and can only find 2025.0.1.
rbunger
New Contributor II
There is a selection box ("Choose your version") where you can select 2024.2.1.
rbunger
New Contributor II
many thanks for your efforts!
Kind regards
Rainer
Aleksandra_K
Aleksandra
rbunger
New Contributor II
It works with the 2025.1, many thanks!
Kind regards,
Rainer
