openAPI MKL + i5-11th gen+ LabVIEW
_Bear84_
Hello
Recently I have faced the problem of using LabVIEW functions related to Math Kernel Library (MKL). During development, the error loading appeared to me "...\resource\lvanlys.dll" A dynamic link library (DLL) initialization routine failed."
My investigation led me to National Instruments resources related to the same problem - link. But I was wondering that all mentioned their processors were AMD, but in my case, it's Intel. Recommended solution with an environment variable MKL_DEBUG_CPU_TYPE =4 didn't help in my case.
My configuration is:
- Windows 10 LTSC(1809) x64
- LabVIEW 2018.0f2 (32-bit)
- Intel(R) Core(TM) i5-1135G7 (4 cores)
Why do I blame the processor? Because the same configuration on the i7-8750H works well.
I have updated Intel oneMKL to the actual version (2022.1.0.192), but nothing changed.
The question is: Is it possible to configure my system (OS env. variables, e.t.c) to get the correct usage of MKL in the LabVIEW IDE? How should it be done?
ShanmukhS_Intel
Thank you for posting on Intel communities.
Please refer to the below link regarding the prerequisites for Intel oneAPI Math Kernel Library.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/oneapi-math-kernel-library-system-requirements.html
Shanmukh.SS
ShanmukhS_Intel
Reminder:
We haven't heard back from you for a while. Could you please let us know if the information provided helped?
Shanmukh.SS
ShanmukhS_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
