optimize 1D FFT performance
Bo_Q_
I am trying to apply 1D FFT to a 3D matrix along a single direction. Below is the code I am currently using. It has a nested loop to loop through the other 2 dimensions. It works but I am just wondering if there is any ways to speedup this code. The size of the FFT is typically under 1024 points.
status = DftiCreateDescriptor(hFFT,DFTI_DOUBLE,DFTI_COMPLEX,1,nFFT)
status = DftiSetValue(hFFT,DFTI_COMPLEX_STORAGE,DFTI_REAL_REAL)
status = DftiCommitDescriptor(hFFT)
do j = 1,nz
    do i = 1,ny
        status = DftiComputeForward(hFFT,datarel(:,i,j),dataimg(:,i,j))
    end do
end do
status = DftiFreeDescriptor(hFFT)
Thanks!
Ying_H_Intel
Hi
The nested loop looks ok for me.  and  as you see from  https://software.intel.com/en-us/node/433474#FFT
1024 1D complex FFt is not multithreaded.  So if you are working on mult-core machines, you may try the multi-thread the batched 1D 1024 point FFT by any methods. like in MKL userguide :
Examples of Using Multi-Threading for FFT Computation  => Using Parallel Mode with a Common Descriptor
or
https://software.intel.com/en-us/articles/different-parallelization-techniques-and-intel-mkl-fft
Ying
Ying_H_Intel
Hi
or
Ying
