7303 Discussions
pardiso compilation c language HPC Linux OneApi 2021
AlexandreL
Good afternoon,
I would like to use the pardiso unsymmetric procedure in C.
I am using a HPC Linux 64 bits Redhat 7.9, with OneAPI 2021 installed.
Could someone please provide a simple C example of pardiso unsym .c algorithm, as well as the compilation instructions (setting the environment, compilation instruction, etc).
That would be greatly appreciated!
thanks in advance for your help,
VarshaS_Intel
Yes, as you are using Intel MKL on a Linux machine, you can find all the MKL sample codes in this /opt/intel/oneapi/mkl/latest/examples directory path you can untar and keep these examples in another folder( as Intel oneAPI path is a readable folder)
As you want to run the pardiso unsym.c example, you can go to the path where you have untared the file and go to c/sparse_directsolvers/source then you can find the example pardiso_unsym.c
At first, we need to initialize the Intel oneAPI environment for Intel MKL and Intel Compilers(C, C++, Fortran)
source /opt/intel/oneapi/setvars.sh
Now, for compiling you can use the Intel link line advisor for proper linking of your code. And also, please find this documentation for other linking options.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-1/linking-your-application-with-onemkl.html
Compiling : icpx -DMKL_ILP64 -I"${MKLROOT}/include" pardiso_unsym.c -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_ilp64.a ${MKLROOT}/lib/intel64/libmkl_sequential.a ${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--en d-group -lpthread -lm -ldl
Running : ./a.out
Please find the below screenshot where we tried for pardiso_unsym.c code,
For more details, regarding getting started for Intel MKL, please find the below links:
https://www.intel.com/content/www/us/en/docs/onemkl/get-started-guide/2023-0/overview.html
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2023-1/overview.html
Could you please let us know if you have any other queries?
Thanks & Regards,
Varsha
AlexandreL
Dear Varsha,
Thanks a lot for your support!
Since my message posted yesterday, I managed to successfully compile using the "mkl link tool" to give me the compilation options :
icc pardiso_unsym_c.c -DMKL_ILP64 -I"${MKLROOT}/include" -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_ilp64.a ${MKLROOT}/lib/intel64/libmkl_intel_thread.a ${MKLROOT}/lib/intel64/libmkl_core.a ${MKLROOT}/lib/intel64/libmkl_blacs_intelmpi_ilp64.a -Wl,--end-group -liomp5 -lpthread -lm -ldl -o pardiso_unsym_c
Unfortunately, during execution, I add an error message with libiomp5.so!
I was stuck again, and your reply came handy:
I first initialised the environment variables as you recommended :
source /opt/cluster/tools/intel/2021.4/setvars.sh
then I tried to compile using your command :
Unfortunately it gave an error regarding d-group...
However I tried to recompile the code using my command above (icc ...) after initialising the environment variables using your command, and it successfully compiled... and ran!
In conclusion, I found out that:
my compilation command is OK
the environment variables need to be set before execution, using source /opt/cluster/tools/intel/2021.4/setvars.sh
Thanks to you, I also found out that I add the tgz examples installed in the directories, which I did not know (I did not install OneApi myself). I had recovered a pardiso_unsym.c version from the internet which might be a little older that the one officially provided with OneApi 2021. I will then use the OneAPI 2021 version from now on.
Thanks again for the support, that helped me get the algorithm working and get the recent version!
VarshaS_Intel
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Have a Good Day!
Thanks & Regards,
Varsha
