pardiso free() memory errors
mbhealy
I am trying to use pardiso to solve a matrix inversion problem. I have made a small example to test out my calls to the solver. When I run my example I receive the following message:
*** glibc detected *** free(): invalid next size (fast): 0x00000000009f34b0 ***
Abort
The code for my example is as follows:
void *pt[64];
for(int i=0;i<64;i++) {pt = 0;}
int maxfct = 1;
int mnum = 1;
int mtype = -2; // real symmetric positive indefinite
int phase = 13; // do all steps, analysis, factor, solve, refine
int n = 6;
int *perm = NULL; // pardiso does it's own permutation
int nrhs = 18; // number of equations = num columns of E = size of interface
int *iparm = NULL;
if(!(iparm = (int *)malloc(64*sizeof(int)))) exit(-1);
iparm[0] = 0; // use default values for now
iparm[2] = 1; // MUST be equal to num threads
mkl_set_num_threads(1);
int msglvl = 1; // print out statistics for now
int error = 0;
double nzval[12] = {109.018, -12.8205, -0.0437675, -83.3333, 31.9348, -0.0437675, 12.5438, -6.25, 18.7938, 83.3333, 1, -20};
int colidx[12] = {0, 1, 2, 4, 1, 3, 2, 3, 3, 4, 5, 5};
int rowptr[7] = {0, 4, 6, 8, 9, 11, 12};
double B[108] = {0, -12.8205, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -12.8205, 0, -6.25, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -6.25, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -6.25, 0, 0, -6.25, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
double X[108];
cout << "starting ";
pardiso_(pt, &maxfct, &mnum, &mtype, &phase, &n, nzval, rowptr, colidx, perm, &nrhs, iparm, &msglvl, B, X, &error);
I am using C++ code with the gcc compiler and am statically linking with the libmkl_solver_lp64.a library. The compilation and linking steps produce no errors or warnings.
Any clues why this does not work?
Also, is B expected in row-major or column-major order?
For example, if b(i) = i; Then the matrix B should be:
1 2 3
4 5 6
7 8 9 = row-major
or
1 4 7
2 5 8
3 6 9 = col-major
-Michael-
mbhealy
I may have missed this somewhere in the documentation, but apparently even the C version of Pardiso expects 1 based indexing.
The code above provides correct results when you increment every element of the colidx and rowptr arrays (corresponding to ja and ia in the documentation).
