pdgetrf in mixed language
phaser75
I exercise LAPACK in c language. I want to factorize a matrix(2X2) but it doesn't work.
I don't have any idea what is the problem.
The simple code is like this. The error message says there is a problem in 4th parameter(lda).
#include
#include
#include "mkl.h"
#define NRANSI
#include "NRUTIL.h"
#define PI (3.141592653589793)
int main(int argc, char* argv[])
int m, n, lda, info;
double **A, d;
int *ipiv;
A = dmatrix(1,2,1,2);
ipiv = ivector(1,2);
m = 2;
n = 2;
lda = 2;
A[1][1] = 4.0;
A[1][2] = 1.0;
A[2][1] = 3.0;
A[2][2] = -1.0;
printf("This is TEST!!!\n");
dgetrf(&m, &n, &A[1][1], &lda, &ipiv[1], &info);
printf("info = %d\n",info);
free_dmatrix(A,1,2,1,2);
free_ivector(ipiv,1,2);
return 1;
Gennady_F_Intel
Quoting - phaser75
#include
#include
#include "mkl.h"
#define NRANSI
#include "NRUTIL.h"
double **A, d;
int *ipiv;
m = 2;
n = 2;
lda = 2;
A[1][1] = 4.0;
A[1][2] = 1.0;
A[2][1] = 3.0;
A[2][2] = -1.0;
printf("This is TEST!!!n");
printf("info = %dn",info);
return 1;
please try in that way:
A[0][0] = 4.0;
A[0][1] = 1.0;
A[1][0] = 3.0;
A[1][1] = -1.0;
dgetrf(&m, &n, &A[0][0], &lda, &ipiv[1], &info);
it should work.
--Gennady
phaser75
Quoting - phaser75
I still have the error.
The message is "MKL ERROR : Parameter 4 was incorrect on entry to DGETRF
info = -4".
Gennady_F_Intel
Quoting - phaser75
#include
#include
#include "mkl.h"
#define NRANSI
#include "NRUTIL.h"
double **A, d;
int *ipiv;
m = 2;
n = 2;
lda = 2;
A[1][1] = 4.0;
A[1][2] = 1.0;
A[2][1] = 3.0;
A[2][2] = -1.0;
return 1;
A[0][0] = 4.0;
A[0][1] = 1.0;
A[1][0] = 3.0;
A[1][1] = -1.0;
it should work.
--Gennady
the same with &ipiv[0] not &ipiv[1]
phaser75
Thank you for replying but it still doesn't work. Error message is same.
ArturGuzik
Valued Contributor I
Quoting - phaser75
check this thread. You have double indexed matrices here.
for statically allocated matrices example of using LAPACK is here.
A.
phaser75
Quoting - ArturGuzik
A.
Thank you. But it is the same.
I tried static allocation and one dimensional array as well. But the same error occurred.
What's the problem?
phaser.
ArturGuzik
Quoting - phaser75
What's the problem?
phaser.
OK then. This is working for me (static for simplicity).
[cpp]//
#include
#include "mkl_lapack.h"
#define MAX 2
int main(){
// data
int n, m;
int nrhs = 1;
double A[MAX][MAX];
double b[1][MAX];
int lda = MAX;
int ldb = MAX;
int ipiv[MAX];
int info;
// Other values
int i,j;
// dimension(s)
m=2;
n=2;
// value(s)
A[0][0] = 2.0;
A[0][1] = 0.0;
A[1][0] = 0.0;
A[1][1] = -2.0;
b[0][0]=1.0;
b[0][1]=2.0;
// factorize
dgetrf(&m, &n, &A[0][0], &lda, &ipiv[0], &info);
// solve
dgetrs("N", &n, &nrhs, &A[0][0], &lda, &ipiv[0], &b[0][0], &ldb, &info);
// Check for success
if(info == 0)
// Write the answer
std::cout << "The answer isn";
for(i = 0; i < n; i++)
std::cout << "b[" << i << "]t" << b[0] << "n";
else
// Write an error message
std::cerr << "dgetrf returned error " << info << "n";
return info;
[/cpp]
A.
redleaf
I've got the same problem with using the MKL library.
I've just found out that the problem lies in the parameters' data type.
Actually there's some incompatibility between Int32 and Int64.
Declared as MKL_INT, variables were interpreted as Int32 at compile time.
Nevertheless it was linked with the mkl_intel_ilp64, hence when I pass the address of an "int" instead of a "long int", the function might get a zero value. In this case the matrix leading. It leads to this error.
The problem is solved by simply changing the type of lda, m and n to long int.
