problem linking mkl to dft
juan_martinez
hi!
I am new in the stuff of the intel fortran compiler, I work in beam prpagation and need tu use Fourier Transform. I installed the fortran compiler 10.1.008 and the imkl 10.0.1.014 and read the examples of the refence manual for the imkl I made this program:
program fft
! Fortran example.
! 1D complex to complex, and real to conjugate even
USE MKL_DFTI
Complex :: X(100)
Real :: Y(34),del,x1
type(DFTI_DESCRIPTOR),POINTER ::My_Desc1_Handle,My_Desc2_Handle
Integer :: Status,i,j,n
pi=3.1416
n=100
open(unit=3,file='graficos.d')
del=2*pi/float(n)
do i=0,n-1
x1=-pi+i*del
X(i+1)=exp(-x1**2)
write(3,*)x1," ",X(i)
enddo
!...put input data into X(1),...,X(32); Y(1),...,Y(32)
! Perform a complex to complex transform
Status = DftiCreateDescriptor(My_Desc1_Handle,DFTI_SINGLE,DFTI
+_COMPLEX,1,32)
Status = DftiCommitDescriptor( My_Desc1_Handle )
Status = DftiComputeForward( My_Desc1_Handle, X )
Status = DftiFreeDescriptor(My_Desc1_Handle)
! result is given by {X(1),X(2),...,X(32)}
! Perform a real to complex conjugate even transform
! Status = DftiCreateDescriptor(My_Desc2_Handle, DFTI_SINGLE,DFTI
! +_REAL, 1, 32)
! Status = DftiCommitDescriptor(My_Desc2_Handle)
! Status = DftiComputeForward(My_Desc2_Handle, Y)
! Status = DftiFreeDescriptor(My_Desc2_Handle)
! result is given in CCS format.
END
And I read the user guide and Imade this compilation line:
ifort -o exec ejemplo1.f -L $/opt/intel/mkl/10.0.1.014/lib/32/ -I $/opt/intel/mkl/10.0.1.014/include/ -lmkl_ia32 -lguide -lpthread
And then the machine shows this errors
fortcom: Error: ejemplo1.f, line 7: Error in opening the compiled module file. Check INCLUDE paths. [MKL_DFTI]
USE MKL_DFTI
fortcom: Error: ejemplo1.f, line 10: This derived type name has not been declared. [DFTI_DESCRIPTOR]
compilation aborted for ejemplo1.f (code 1)
I don't know what happen here, if someone can help me say me where is the error, in the program? in the compilation line?
My OS is penSUSE 10.3, 32 bits, i386
Tabrez_Ali
You have to compile the module first. The source file is probably provided in /opt/intel/mkl/10.0.1.0.14/include as mkl_dfti.f90 or something similar
Also link using -L/opt/intel/mkl/10.0.1.0.14/lib/32 -lmkl_ia32 -lguide etc. etc.
