problem using c++ version of dgesv
geowolf
Dear all,
please find below two times the same sample code.
Purpose is to to solve a system of linear equations of matrix A and matrix B. However, the resulting Matrix B differs.
The Fortran version gives the correct, the C++ a wrong result.
Can anyone tell me what is wrong with the C++ source?
This is the (incorrect) C++ version:
[cpp]#include "mkl.h"
#include
#include
using namespace std;
#define NI 4
#define NJ 3
int main(int argc, char* argv[])
double a[NI][NI];
double b[NI][NJ];
a[0][0] = 1;
a[0][1] = 1;
a[0][2] = 1;
a[0][3] = 1;
a[1][0] = 7.4895;
a[1][1] = 7.5292;
a[1][2] = 7.3905;
a[1][3] = 7.4141;
a[2][0] = 1.1759;
a[2][1] = 1.2956;
a[2][2] = 1.2342;
a[2][3] = 1.3149;
a[3][0] = 0.1496;
a[3][1] = 0.3214;
a[3][2] = 0.2887;
a[3][3] = 0.1598;
b[0][0] = 0;
b[0][1] = 0;
b[0][2] = 0;
b[1][0] = 1;
b[1][1] = 0;
b[1][2] = 0;
b[2][0] = 0;
b[2][1] = 1;
b[2][2] = 0;
b[3][0] = 0;
b[3][1] = 0;
b[3][2] = 1;
cout << "A1 = \n";
for(int i = 0; i < NI; i++)
for(int j = 0; j < NI; j++)
cout << a << "\t";
cout << "\n";
cout << "\n";
int ipiv[NI];
for (int i = 0; i < NI; i++){
ipiv = 0;
cout << "B1 = \n";
for(int j = 0; j < NJ; j++)
cout << b << "\t";
cout << "\n";
cout << "\n";
int n = NI;
int nrhs = NJ;
int lda = NI;
int ldb = NI;
int info = -1;
dgesv(&n, &nrhs, *a, &lda, ipiv, *b, &ldb, &info);
cout << "INFO = " << info << "\n";
cout << "G = \n";
cout.setf(std::ios::scientific);
cout << b << "\t";
cout << "\n";
cout << "\n";
return 0;
[/cpp]
And here is the (correct) Fortran version:
[fxfortran]      PROGRAMM TEST
      IMPLICIT NONE
      DOUBLE PRECISION A(4,4), B(4,3)
      INTEGER N,NRHS,LDA,INFO,LDB,I,J
      DOUBLE PRECISION IPIV(4)
      N = 4
      NRHS = 3
      LDA = 4
      LDB = 4
      A(1,1) = 1
      A(1,2) = 1
      A(1,3) = 1
      A(1,4) = 1
      A(2,1) = 7.4895
      A(2,2) = 7.5292
      A(2,3) = 7.3905
      A(2,4) = 7.4141
      A(3,1) = 1.1759
      A(3,2) = 1.2956
      A(3,3) = 1.2342
      A(3,4) = 1.3149
      A(4,1) = 0.1496
      A(4,2) = 0.3214
      A(4,3) = 0.2887
      A(4,4) = 0.1598
      B(1,1) = 0
      B(1,2) = 0
      B(1,3) = 0
      B(2,1) = 1
      B(2,2) = 0
      B(2,3) = 0
      B(3,1) = 0
      B(3,2) = 1
      B(3,3) = 0
      B(4,1) = 0
      B(4,2) = 0
      B(4,3) = 1
      DO I = 1, 4
      IPIV(I) = 0.0
      WRITE(*,'(4(F10.4))') (A(I,J), J = 1, 4)
      ENDDO
      DO I = 1, 4
      WRITE(*,'(4(F10.4))') (B(I,J), J = 1, 3)
      ENDDO
      CALL DGESV(N,NRHS,A,LDA,IPIV,B,LDB,INFO)
      WRITE(*,*) 'INFO = ', INFO
      DO I = 1, 4
      ENDDO
      END
[/fxfortran]
Kind regards
Wolfram
mecej4
C stores a matrix with row-1 first, then row-2,...
Fortran stores a matrix with col-1 first, then col-2,...
Unless your matrix is symmetric, you need to take these facts into consideration. Alternatively, use the C-Lapack interface which gives you wrappers around the Fortran routines with the ability to specify the storage order of the matrices, etc.
Gennady_F_Intel
please see the DGESV C Example here.
geowolf
Dear all,
the respective discrete links to the mentioned examples are:
http://software.intel.com/sites/products/documentation/hpc/mkl/lapack/mkl_lapack_examples/dgesv.htm#top
and for the version which is the one which applies here (row major) it is
http://software.intel.com/sites/products/documentation/hpc/mkl/lapack/mkl_lapack_examples/lapacke_dgesv_row.c.htm
Please find below a corrected version of the C++ source which gives a result identical to the Fortran version.
The main differences are the usage of:
info = LAPACKE_dgesv(LAPACK_ROW_MAJOR, n, nrhs, *a, lda, ipiv, *b, ldb);
and a fix concerning the size of ldb which has to be identical to nrhs (i.e. NJ). (The size of a is [NI][NI] while the size of b is [NI][NJ]!)
#include "mkl_lapacke.h"
#include
#include
#define NI 4
#define NJ 3
	double a[NI][NI];
	double b[NI][NJ];
	a[0][0] = 1;
	a[0][1] = 1;
	a[0][2] = 1;
	a[0][3] = 1;
	a[1][0] = 7.4895;
	a[1][1] = 7.5292;
	a[1][2] = 7.3905;
	a[1][3] = 7.4141;
	a[2][0] = 1.1759;
	a[2][1] = 1.2956;
	a[2][2] = 1.2342;
	a[2][3] = 1.3149;
	a[3][0] = 0.1496;
	a[3][1] = 0.3214;
	a[3][2] = 0.2887;
	a[3][3] = 0.1598;
	b[0][0] = 0;
	b[0][1] = 0;
	b[0][2] = 0;
	b[1][0] = 1;
	b[1][1] = 0;
	b[1][2] = 0;
	b[2][0] = 0;
	b[2][1] = 1;
	b[2][2] = 0;
	b[3][0] = 0;
	b[3][1] = 0;
	b[3][2] = 1;
	cout << "A1 = n";
	for(int i = 0; i < NI; i++) {
		for(int j = 0; j < NI; j++) {
			cout << a << "t";
		cout << "n";
	cout << "n";
	MKL_INT ipiv[NI];
		ipiv = 0;
	cout << "B1 = n";
		for(int j = 0; j < NJ; j++) {
			cout << b << "t";
		cout << "n";
	cout << "n";
	MKL_INT n = NI;
	MKL_INT nrhs = NJ;
	MKL_INT lda = NI;
	MKL_INT ldb = NJ;
	MKL_INT info = -1;
	cout << "INFO = " << info << "n";
	cout << "G = n";
			cout << b << "t";
		cout << "n";
	cout << "n";
	return 0;
[/cpp]
Kind regards
Wolfram
