7303 Discussions
problems with installation: package intel-mkl-8.0.2p-4.noarch has unsatisfied Requires: /bin/sh
antonioparodi74
I am trying to install the Intel Math Kernel Library (Intel MKL) 8.1 on my linux cluster (debian linux).
However the installation crashes since I have got the following error message:
D: found 0 source and 1 binary packages
D: opening db environment /var/lib/rpm/Packages joinenv
D: opening db index /var/lib/rpm/Packages rdonly mode=0x0
D: locked db index /var/lib/rpm/Packages
D: ========== +++ intel-mkl-8.0.2p-4 noarch/linux 0x0
D: opening db index /var/lib/rpm/Depends create mode=0x0
D: opening db index /var/lib/rpm/Basenames rdonly mode=0x0
D: opening db index /var/lib/rpm/Providename rdonly mode=0x0
D: Requires: /bin/sh NO
D: package intel-mkl-8.0.2p-4.noarch has unsatisfied Requires: /bin/sh
D: Requires: rpmlib(PayloadFilesHavePrefix) = 4.0-1 YES
(rpmlib provides)
D: Requires: rpmlib(CompressedFileNames) = 3.0.4-1 YES
(rpmlib provides)
D: opening db index /var/lib/rpm/Conflictname rdonly mode=0x0
D: closed db index /var/lib/rpm/Depends
D: closed db index /var/lib/rpm/Conflictname
D: closed db index /var/lib/rpm/Providename
D: closed db index /var/lib/rpm/Basenames
D: closed db index /var/lib/rpm/Packages
D: closed db environment /var/lib/rpm/Packages
error: Failed dependencies:
/bin/sh is needed by intel-mkl-8.0.2p-4.noarch
D: ========== recording tsort relations
D: ========== tsorting packages (order, #predecessors, #succesors,
tree, depth, breadth)
D: 0 0 0 0 1 0 +intel-mkl-8.0.2p-4.noarch
D: May free Score board((nil))
Mon 06 21:06:37: Error - install.sh:1175 Failed to install product
Do you have any idea or comments?
thank you for your help
Antonio
TimP
Did you get the required root privilege for install?
