7302 Discussions
real matrix -- eigenvector matrix R -- diagonal eigenvalue matrix L
diedro
Hi every one,
I have the following problem:
I have a real matrix A=nxn and I would like to compute theeigenvector matrix R and diagonal eigenvalue matrix L with mkl libraries.
I don't know what subroutine I could use.
I have already useddgeev_f95 for other purpose but Id give to me vector and not matrix
thank a lot
mecej4
Diagonal matrices are rarely stored as full matrices, since that would waste a lot of memory. The routine GEEV returns two 1-D arrays containing the real and imaginary parts of the eigenvalues -- a real matrix, even a symmetric one, may have complex eigenvalues. It is trivial to place these eigenvalues on the diagonal of a zeroed-out square complex matrix.
Please state if you know anything more about the matrix A, and explain why you found the output of GEEV unsatisfactory.
diedro
hi,
ok, thanks for your help and advices.
The matrix A is a real matrix nxn
The GEEV gives to me the vector of eigenvalues, while I need the matrix of eigenvalues.
this because I need to comute:
Q= 0.5*R*(Id+sign(L-xi*Id))*iR*QL + 0.5*R*(Id-sign(L-xi*Id))*iR*QR;
where Q is n vector,
R is the eigenvector matrix and
L is diagonal eigenvalue matrix.
QR is n vector and QL is n vector.
Id is the nxn identity matrix.
IR isthe inverse of the eigenvector matrix R
Geev does not give me the L in matrix form.
thanks a lot
mecej4
I think that you can compute Q quite easily using only the main diagonal held as a vector, but I must first ask you to clarify a couple of items.
(i) xi is a scalar, yes?
(ii) How is the function sign() defined when it operates on (a) a diagonal matrix and, if this is meaningful, (b) a vector?
diedro
hi,
i) xi is a scalar (my adimensinal coordinate)
ii) for example:
L= 1.4142 0
0 -1.4142
then sign(L)= 1 0
0 -1
Thanks a lot
mecej4
I am answering purely from an algorithmic viewpoint, since I do not know the application domain and how the matrices relate to anything physical or conceptual.
Let M1 be a diagonal matrix, with elements
i = +1 if i > and 0 if i <
Let matrix S1 = R.M1. You can compute column j of S1 by multiplying column j of R by j . Then, you can compute the first part of the desired result q = q1 + q2 as
q1 = S1 R-1 q L
You can compute the second part q2 similarly, using M2 = the 1s-complement of M1 and qR in place of M1 and qL, respectively.
Throughout what I wrote, you would compute the produce q L not as a vector-matrix product, but simply by multiplying each element of q by the corresponding . That is, computing q L is an element-by-element product of two vectors, q and diag(L).
Please check the equations, since some browsers may not display subscripts, etc. correctly. For example Firefox 3.16 does not show the inverse ("-1") in the equation for q1 correctly, but IE does.
diedro
Thank a lot but what I am doing is a very simple code to use lapack libraris in fortran95 and to use matrix annotation.
This because After that I use the some source code for a more complex problem.
If I had L a could compute Q with somematmul function. this is the main reason because I ask for a different mls-lapack library, to compute
L as a11 0
0 a22
and not as L
a11
a22
what do you think about it?
mecej4
Many procedures of mathematics, in particular matrix operations, are inefficient if implemented on a computer in the most direct and elementary way. For example, the expression of the solution of A.x = b as x = A-1b is fine in a mathematics book or a mathematical derivation. However, computing the inverse explicitly and then multiplying the vector b by the inverse takes twice the computational effort and is often going to give less accurate results than Gaussian elimination with partial pivoting.
Multiplying two diagonal matrices of size n X n takes O(n) operations if done right, and O(n3) operations if the full matrices are used in a MATMULT call.
Please read a book such as Golub and van Loan's Matrix Computations.There are also many good articles on this topic on the Web.
For these reasons, I think that I would be doing you a disservice by telling you how to form a diagonal matrix from a vector containing the main diagonal. Not only is that trivial to do, but doing it is a temptation that I wish to help you avoid.
diedro
hi,
I'm sorry for delay. So what do you suggest for:
to compute Q,
could I use some lapack libraries? or solve them in anothe way?
thanks a lot
diedro
hi,
to compute Q,
thanks a lot
