reduce the size of the resulted dll?
Zhong_Fan
hi, I have built a wrap dll to use the PARDISO solver in MKL 10.3 (no other function is introduced besides pardiso), MKL is static linked with:
mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libiomp5mt.lib
the building environment is vs2005 release mode.
now the problem is thatthe resulted dll isso large ( > 9M ), is there anyway to reduce its size?
note that dynamic linkage is not considered because i want to reduce the total size of the redistributed files.
Thanks!
Gennady_F_Intel
you can try to build custom dll with PARDISO function only, but I don't think if it much help.
--Gennady
