7298 Discussions
scalapack problem when loading mkl_blacs_intelmpi_ilp64.2.dll
wzc
Hello everyone,
  I am running the "scalapack" example code. However, the Terminal showed the following error information: Intel MKL FATAL ERROR: Cannot load mkl_blacs_intelmpi_ilp64.2.dll.
  How could I solve this problem?
SofeaAzrin_A_Intel
Hi wzc,
Thanks for your question.
This is a typical issue when the path is not properly installed. Please find out your systems installed the path correctly. Or else, you can copy the dll files to the execution place.
You can refer to this link for reference too.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-windows/2024-0/setting-environment-variables.html
Sofea
SofeaAzrin_A_Intel
Hi wzc,
Sofea
