short int or char in viRngUniform
dario_suarez
I'm usign large array of very small random numbers, often between 0 and 10. This large arrays consume 4 bytes per entry (int), and I would like to know if there is a way for generating arrays of short int and chars to save memory.
Thanks in advance for your help,
Daro
Sergey_M_Intel2
Hello Dario,
Unfortunately there is no 8-bit or 16-bit variant of the uniform RNG in MKL. The only workaround that I see is to generate the data by portions as 32-bit integers and process those integers in a way you need. It will save the storage.
If for some reason youneed to store entire array of chars you still can generate it by blocks by converting each block into array of bytes, something like this:
#define N (1024*1000)
#define BLOCK_SIZE 1024
int block[BLOCK_SIZE];
char urng;
... //Create the random stream
for (i=0; i
// Generate block of 32-bit integers
viRndUniform(0, stream, BLOCK_SIZE, block, 0, 10);
for (j=0; j
urng[i+j] = (char)block;
... // Delete the random stream
That may help,
Sergey
Sergey_M_Intel2
Hello Dario,
char urng;
for (i=0; i
for (j=0; j
That may help,
Sergey
dario_suarez
Hi Sergey,
Thanks. The idea of blocking seems very good. I'll implement it and see the effect on memory and performance.
Daro
