7297 Discussions
solving system of linear algebraic equations, dgesv
shapovalov
I want to solve system of linear algebraic equations with function dgesv. I want to understand how to use MKL functions from C++, but all examples are written forFortran.
double a1[16]={1.80, 2.88, 2.05, -0.89,
5.25, -2.95, -0.95, -3.80,
1.58, -2.69, -2.90, -1.04,
-1.11, -0.66, -0.59, 0.80};
double b1[4]={9.52, 24.35, 0.77, -6.22};
int N1=1,info,Size=4;
int *ipiv = new int[Size];
dgesv(&Size,&N1,a1,&Size,ipiv,b1,&Size,&info);
Arrayb1 must contain solution of system (1,-1,3,-5), but it contains other values(-1.37, -9.78, 10.53, -42.06).
What's my mistake? May be, because ofindexing? (in C++ from 0, in Fortran from 1)
And I shoulddefine arrays a1 and b1as
double a1[16]={ 0, 0, 0, 0, 0,
0, 1.80, 2.88, 2.05, -0.89,
0, 5.25, -2.95, -0.95, -3.80,
0, 1.58, -2.69, -2.90, -1.04,
0, -1.11, -0.66, -0.59, 0.80};
double b1[4]={0, 9.52, 24.35, 0.77, -6.22};
Or not?
ArturGuzik
Valued Contributor I
Quoting - shapovalov
Or not?
I might be wrong but:
(1) dgesv is LAPACK function
(2) it takes a coefficient matrix, that is, A, and not A[m x m] (observe size/indexing issue)
(3) for LAPACK call consider matrix reordering (to Fortran style column-wise), passing first argument may go (may not?) into play.
(4) LAPACK also requires passing data by address and not value
All that is summarized, for example, here.
A.
shapovalov
Thank you very much. I realized what my mistake. The matrixashould be transposed.
