7302 Discussions
solving underdetermined system and LAPACKE_dormqr error
Azua_Garcia__Giovann
Trying to do the same as in Matlab (snippet below) but using MKL produces at the point of doing the Q'*b with LAPACKE_dormqr "MKL ERROR: Parameter 10 (ldb) was incorrect on entry to cblas_dtrsm". Is it a valid case trying to solve underdetermined systems with MKL? I know this doesn't make a lot of sense i.e. infinite solutions but Matlab is quite robust in that respect.
I managed to get the append column QR update bit working green unit tests yippiiiii :) and this underdetermined system was a border case test which results in the MKL error above.
Thanks in advance,
Giovanni
>> A =[9.572000e-01 1.419000e-01 7.922000e-01 3.570000e-02 6.555000e-01;
4.854000e-01 4.218000e-01 9.595000e-01 8.491000e-01 1.712000e-01;
8.003000e-01 9.157000e-01 6.557000e-01 9.340000e-01 7.060000e-01]
A =
0.9572 0.1419 0.7922 0.0357 0.6555
0.4854 0.4218 0.9595 0.8491 0.1712
0.8003 0.9157 0.6557 0.9340 0.7060
>> b = [0.0318; 0.2769; 0.0462]
b =
0.0318
0.2769
0.0462
>> A\\b
ans =
0
0
0.2745
0.0739
-0.2872
mecej4
If you have an undetermined system, with A an m X n matrix, rank(A) = m < n, and you want the minimum norm solution, you can use the LQ factorization. See the MKL Reference Manual under LAPACK Routines: Least Squares and Eigenvalue Problems. To obtain such a solution in Matlab, you would type in
pinv(A)*b
There is an example, dgelqfx.f, and associated input data dgelqfx.d, in the MKL examples/lapack directory. With this code, but your data above, I get the minimum norm solution as
-0.0540
-0.0954
0.2668
0.1395
-0.1821
which agrees with the result from the Matlab calculation pinv(A)*b.
If you want help with a problem with calling MKL, at a minimum you have to show the routine invocation and the declarations of the routine arguments. It would be better to post a complete example, if feasible.
