sparse_matrix_checker error value constants
Eugene_S_1
The MKL manual lists the following constants for the error value returned by the sparse_matrix_checker subroutine: MKL_SPARSE_CHECKER_SUCCESS, MKL_SPARSE_CHECKER_NON_MONOTONIC, MKL_SPARSE_CHECKER_OUT_OF_RANGE, MKL_SPARSE_CHECKER_NONTRIANGULAR and MKL_SPARSE_CHECKER_NONORDERED.
Where are they defined?
Thank you.
Ying_H_Intel
Hi Eugene,
Thanks you for asking. It seem we really miss these definitions.  I will check the latest version and update you if any news.
Ying H.
Intel MKL Support
Gennady_F_Intel
Eugene, thanks for the issue. We missed to add this info into header files. We will add this info later into one of the updates.
here is info which we missed to add.
MKL_SPARSE_CHECKER_SUCCESS,  = 0
MKL_SPARSE_CHECKER_NON_MONOTONIC = 21,
MKL_SPARSE_CHECKER_OUT_OF_RANGE,  = 22
MKL_SPARSE_CHECKER_NONTRIANGULAR = 23
MKL_SPARSE_CHECKER_NONORDERED = 24
hope that helps.
--Gennady
Eugene_S_1
Thank you very much. Now it's clear where the magic number 23 in matrix_check.f90 comes from.
Gennady_F_Intel
here is the original ja array
JA = (/ 1,    3,       6, 7,
     .             2, 3,    5,
     .                3,             8,
     .                   3,       7,
     .                      5, 6, 7,
     .                         6,    8,
     .                            7,
     .                               8 /)
*** Input check: i=4, j=ia(i)=10, ja(j)=3 are incompatible
Matrix check result code: 23
Matrix check details: (4, 10, 3)
but here how it could be
JA = (/ 1,    3,       6, 7,
     .             2, 3,    5,
     .                3,             8,
     .                   4,       7,
     .                      5, 6, 7,
     .                         6,    8,
     .                            7,
     .                               8 /)
Matrix check result code: 0
Matrix check details: (0, 0, 0)
I hope that helps
