sparse pblas?
Likun_T_
Hello everyone,
I am trying to use MKL to solve sparse matrix multiplication (i.e. C=A*B) in parallel. I found there is sparse blas for sequential code but I am wondering if there is a parallel version of it.
Likun
Gennady_F_Intel
one clarification -- are you asking about mkl_scsrmultcsr(...) routine?
Likun_T_
Hi Gennady,
Thanks for your reply. Yes, this is the subroutine I refer to. However, I notice that mkl_scrsrmultcsr() is for sequential codes only?
best,
Likun
Gennady_F_Intel
Hi Likun, Looking at the sources code I see that the general case is threaded but the 'trans' case has serial implementation. What is your case?
Likun_T_
Hi Gennady,  thanks.  I am wondering if mkl_csrmultcsr can be used in mpi (distributed memory) setting.
Gennady_F_Intel
Hi Likun.    MKL supports Sparse BLAS routines for shared memory system only.    thanks, Gennady
