static link
Dan4
Hi all,
I am trying to link my code statically. The code is dynamically compiled and works fine by the linking options below:
MKL = "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_lp64.so "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_thread.so "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_core.so -L"~/intel/Compiler/11.1/064/mkl/lib/em64t" -liomp5 -lpthread -lm -DMKL_Complex16="std::complex" -static-intel
Now I tried the line below to get static code:
MKL = "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_lp64.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_thread.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_core.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_solver_lp64.a -L"~/intel/Compiler/11.1/064/mkl/lib/em64t" -openmp -lpthread -lm -DMKL_Complex16="std::complex" -static-intel
and when I use above linking, I get many unresolved referenced to almost all MKL functions I have used. Is there anything wrong with the link above? Is it also possible to just provide the path, so the compiler can statically bind all libraries needed? I read somewhere that using "-static-intel" would do such thing, but it didn't help.
D.
Andrey_G_Intel2
Hello danltu.se!
you forgot to use -Wl,--start-group/-Wl,--end-group linker options. So, your link line will look:
MKL = "-Wl,--start-group ~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_lp64.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_intel_thread.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_core.a "~/intel/Compiler/11.1/064/mkl/lib/em64t"/libmkl_solver_lp64.a -Wl,--end-group -L"~/intel/Compiler/11.1/064/mkl/lib/em64t" -openmp -lpthread -lm -DMKL_Complex16="std::complex" -static-intel
Andrey
Dan4
Thanks Andrey, when I compile with the link you said I still get this error:
error while loading shared libraries: libguide.so: cannot open shared object file: No such file or directory
should I still add more libraries to be linked?
D.
Andrey_G_Intel2
danltu.se,
is it link error or you see this message then you are running your application?
Could you provide full link line, compiler version, os name and version?
Andrey
Dan4
No, I see this error when I run my application. I use Linux and Intel C++ compiler. I also used the link you provided in your previous post.
D.
Gennady_F_Intel
you can find this binaries into/opt/intel/Compiler/11.1/072/lib/intel64.
--Gennady
Dan4
Yes I can! But how can I statically link them? I have also used "-lguide" but it didn't help!
Andrey_G_Intel2
danltu.se,
compiler shouldn`t put dependencies to libguide to your application. Looks like this dependency is coming from somewhere else (for example, from third-party libs which you are using in your application). Could you provide FULL link line?
Andrey
