7303 Discussions
static linking when using lapack routine dsytrf
Richard_Kerr
I have the recent 2017 version of the Parallel Studio XE Composer Edition for Fortran Linux
In my program I am calling Lapack routines dsytrf and dsytri2 . I need to statically link the program
In my Makefile I have
$(COMPUTE_INVERSE): $(OBJS)
    $(LNK) $(LDFLAGS)  -o $@ $(OBJS) $(MKLPATH)/libmkl_lapack95_lp64.a $(MKLPATH)/libmkl_blas95_lp64.a  -Wl,--start-group $(MKLPATH)/libmkl_intel_lp64.a $(MKLPATH)/libmkl_intel_thread.a $(MKLPATH)/libmkl_core.a -Wl,--end-group $(LIBS) $(RLIBS)
I defined LDFLAGS =  -static-intel -Bstatic -static-libgcc
I was unsure of what to use for MKLPATH. I initially used MKLROOT, which is set for me when i source /opt/intel/bin/compilervars.sh -arch intel64 -platform linux in my .bashrc file. (If I echo $MKLROOT  i get /opt/intel/compilers_and_libraries_2017.0.098/linux/mkl)
Then i noticed that the libraries such as libmkl_intel_lp64.a are in two places :
$(MKLROOT)/lib/intel64_lin_mic/libmkl_lapack95_lp64.a
$(MKLROOT)/lib/intel64_lin/libmkl_lapack95_lp64.a
My first question is what is the difference?
The first option (_lin_mic) seems to work better.
I still get a linking error though
ld: /opt/intel/compilers_and_libraries_2017.0.098/linux/mkl/lib/intel64_lin_mic/libmkl_intel_lp64.a(_dsytrf_lp64.o): Relocations in generic ELF (EM: 181)
/opt/intel/compilers_and_libraries_2017.0.098/linux/mkl/lib/intel64_lin_mic/libmkl_intel_lp64.a: could not read symbols: File in wrong format
Does anyone know what is going wrong ?
Richard
mecej4
I do not know by which criteria you say that, but note: unless you have MIC hardware or you are doing cross-development with the objective of eventually running the EXE on a target machine with MIC hardware, you should stay away from anything with "mic" in its name.
Typically, MIC hardware is located on an expensive PCIe board, and you would certainly know if you have a MIC board installed in your system/server.
See http://www.intel.com/content/www/us/en/architecture-and-technology/many-integrated-core/intel-many-integrated-core-architecture.html .
Gennady_F_Intel
Richard,
here description  of this difference extracted from MKL User's Guide (https://software.intel.com/en-us/node/528507)
lib/intel64_lin
Static libraries and shared objects for the Intel® 64 architecture
lib/intel64_lin_mic
Static libraries and shared objects for the Intel® MIC architecture
and we would also recommend to check MKL Linker Adviser in the case if some similar issues will be encountered.
regards.
Richard_Kerr
Thanks, I now understand the difference between intel_lin and intel_lin_mc
But I still don't know why I am getting the "Relocations in generic ELF (EM: 181)" and "could not read symbols: File in wrong format" messages.
I have looked at the Linker Advisor and there is nothing there that I haven't tried. I tested both the openMP and sequential threading layer options.
